Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 04-09-2008, 09:42 PM
txmaui txmaui is offline
AC Compressors Manufacturers for Replacements..
Going to replace the original compressor (and other AC parts) on a 1998 K1500. Anyone have feedback on replacement compressor manufacturers? Any to stay away from? Any other tips would also be appreciated.
Thanks,
Old 04-10-2008, 01:26 AM
NoEcm NoEcm is offline
Re: AC Compressors Manufacturers for Replacements..
Thanks,
Take a look at the Sanden HT6 compressor. $195 + shipping on eBay. When buying the compressor, ask for the sealing rings and they will usually throw them in at no charge.
You might want to stay away from the OEM compressor as it is not “keyed” and will twist, eventually causing a body leak. They commonly call the OEM compressors “Belly Leakers” for a reason.
Definitely stay away from a remanufactured compressor.
While you are at it, consider changing the accumulator and orifice at the same time.
Other than that, follow the standard charging procedure.
Good luck!!!
Old 04-10-2008, 12:54 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Go Brand new if you can.
Murry and 4 season ar junk rebuilts.
For quality parts and repair help.
http://www.autoacforum.com/
http://www.ackits.com/merchant2/
MT
Old 04-10-2008, 01:03 PM
wafrederick wafrederick is offline
Banned
Go to your nearest wrecking yard and get an used one.I have great luck with used ones and never had one fail yet.
