Old 04-09-2008, 08:19 PM
SPORTSTER04 SPORTSTER04 is offline
Wont Start After Running
MY 1990 CHEVY SILVERADO 1/2 TON WITH A 350 WILL NOT START AFTER I DRIVE IT SOME WHERE AND SHUT IT OFF AND TRY TO RESTART IT. IT SMELLS LIKE RAW FUEL WHEN I GO TO START IT ALL IT DOES IS KEEP CRANKING NO FIRE. IF I LET IT COOL DOWN IT WILL START RIGHT UP. I JUST REPLACED THE PLUG AND WIRES CAP AND ROTOR. AFTER IT STARTS IT SMOKES BLUE SMOKE AND SMELLS LIKE IT IS RUNNING RICH. IT IS EFI ALSO.
Old 04-09-2008, 08:34 PM
2000CAYukon 2000CAYukon is offline
Re: Wont Start After Running
Most likely the engine coolant temp sensor in the intake manifold near the tstat housing. The ECM uses this temp sensor to control the amount of fuel based on temp. This is similar to a choke on a carb vehicle.
If you have access to a scan tool, you can see if the reading from the sensor is correct or not.
//2000CAYukon
Old 04-09-2008, 08:37 PM
//2000CAYukon
NO SCAN TOOL HERE.
Old 04-09-2008, 09:12 PM
Originally Posted by SPORTSTER04
NO SCAN TOOL HERE.
You could also remove the connector to the engine coolant temp sensor and use a paper clip (or small wire) to bypass the sensor. Low resistance will tell the ECM that the engine is warm and it should start.
If you have an ohm meter, you can read the resistance of the sensor both cold and hot. Cold should should have a higher resistance than cold.
//2000CAYukon
Old 04-09-2008, 09:13 PM
rhandwor rhandwor is offline
Auto Zone and Advanced Auto offer free scans.
Old 04-10-2008, 02:01 PM
j cAT j cAT is offline
it is possible that it is the ECT this could cause the injectors to be turned on too long on a warm start...I suspect a fuel leak down from the injector[s] into cylinder[s] causing this problem as well as a ruptured fuel regulator diaphram...see if after engine shut down fuel rail pressure remains high if it drops quickly this is the area to troubleshoot....
