Old 04-09-2008, 02:59 PM
Micah_Jones Micah_Jones is offline
System
Where should i run the power wire going to my amp? is there a place on the firewall? it will be a 4 guage wire...oh i have a 91 stealth base...
Old 04-09-2008, 03:06 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: System
The positive line needs to get power from the 12v on your battery. You could hook it into the fuse block but as, I'm sure, it already has an inline fuse most people hook the line straight to the positive terminal on the battery.
Old 04-09-2008, 03:16 PM
Re: System
No, I think you misunderstood my quesiton....I meant, where should I run the power line to get it from the battery to the amp?
Old 04-09-2008, 03:40 PM
new2mitsu new2mitsu is offline
Re: System
there is a grommet on the drivers side u should be able to get through
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 04-09-2008, 03:45 PM
Re: System
Maybe a little more specific as to where it is? Is it behind where the fuse box is?
Old 04-09-2008, 04:02 PM
Re: System
i honestly cant remember off the top of my head... stealthee or poly should chime in, theyre the ones that told me
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
Old 04-09-2008, 05:05 PM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
Re: System
Just pull back the carpet, it should be on the firewall near were your pedals are.
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
Old 04-09-2008, 05:45 PM
Polygon's Avatar
The Red Baron
Re: System
Old 04-09-2008, 08:16 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: System
Its actually slightly above the pedals. Pretty easy to see.
Old 04-10-2008, 01:17 PM
Re: System
I found it but now im wondering where i should ground my amp...my sub box is sitting on the back of my back seats and i only have 4 feet of cable to use for the ground...any suggestions?
Old 04-10-2008, 02:01 PM
Re: System
a longer wire?
'93 3000gt VR-4
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Audio
Sony Deck
Old 04-10-2008, 02:16 PM
Sunni Sunni is offline
Re: System
a longer wire?
Thats funny what i usually do is ground it right to the body of the car drill a hole in the floor and put a nice self tapping bolt through it BUT make sure you scrape off the paint where the wire is gonna touch the body or it wont ground.
Old 04-10-2008, 04:42 PM
Re: System
a longer wire?
Shouldnt the ground be as short as possible? anyone else have sugggestions that dont involve drilling through my car?
Old 04-10-2008, 04:48 PM
91STT 91STT is offline
3SNJ Pres
Re: System
Use the seat belt mounting bolt as your ground point or any other bolt that is attached to the body. Just don't use any that go through plastic before the body.
1991 Stealth R/T TT
It looks stock, so it must be.
Old 04-10-2008, 05:36 PM
Re: System
Im pretty sure its not going to reach there...would it work if i put it under the screw holding the hydraulic shock thing for the hatch?
