Old 04-09-2008, 07:49 AM
cjhsa cjhsa is offline
Question 1996 T&C Air Filter - How to change it?
3.8L. How do you change that thing? It seems to be buried in there with no obvious way to get to it. Thanks in advance.
Old 04-10-2008, 01:22 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 1996 T&C Air Filter - How to change it?
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 04-10-2008, 10:34 AM
Thumbs up Re: 1996 T&C Air Filter - How to change it?
Thanks! I see the Chrysler engineers did a really good job making that a simple thing to do.
No wonder I couldn't figure it out!
Old 04-10-2008, 09:36 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Have you changed the rear 3 spark plugs yet? The engineers worked overtime on those little gems.
Old 04-14-2008, 07:56 AM
OK, there is a potential problem with the Autozone instructions as posted. After removing all the connections noted including the cleaner to radiator crossmember bolt, I could not get the entire assembly to come out. It refused to budge. I was lucky to get it back together so I could drive it over to Firestone (local shop open on Sunday).
They helped me at no charge, despite the fact it took the guy 15 minutes to do it. He didn't remove that crossmember bolt. Instead he simply loosened the hose clamp under the resonator and pulled just the upper part out, leaving the air cleaner still attached to the frame. The he swapped out the filter (even that wasn't easy - he had trouble getting the filter box clamped back together).
Anyway, if you do this yourself, DON'T try to take the entire assembly out unless you've done it before. There wasn't enough room in mine to get the thing out in one piece.
Old 04-14-2008, 11:53 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
As I recall, I don't remove the filter housing, just the inlet resonator assembly. Don't recall it being a major deal. I guess Autozone thought their way would make accessing the filter element easier. Who knows. Thanks for passing the info along.
