Old 03-02-2003, 11:08 AM
64 Chevy 64 Chevy is offline
Scratchbuilt fuel rails
Can anyone here give me some advise on how to go about building fuel rails? If anyone has some photos of one that they built that would help also. Thanks in advance.
Why can't I think of any thing clever to put down here?
Old 03-03-2003, 07:05 AM
hirofkd's Avatar
hirofkd hirofkd is offline
Fuel lines can be made from electric wires of various sizes, but this is very specific to each engine.
Which car or engine are you talking about?
Hiroaki Fukuda
Old 03-03-2003, 07:16 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
I was thinking about this lastnight, and i found some rectangular prism like balsa wood that you cood make some out of. The dimensions are as follows
H=2mm
W=3mm
L=30cm
I used the metric system because it matches up easier.
-Mike
Old 03-03-2003, 01:13 PM
primera man's Avatar
"P-Man"
Be alot of work to scratch build one...you would be better off buying a kit and detailing it
View All My Models Here.
Old 03-03-2003, 06:03 PM
hirofkd: The engine i am talking about is a small block chevy with hilborn fuel injection. so i am going to need one for each cylinder bank.
P-man: What were you trying to show me in that pict?
Any other ideas people?
Old 03-03-2003, 09:48 PM
Murco's Avatar
Murco Murco is offline
Maximum Car Guy
Send a message via Yahoo to Murco
Are you modeling an original set-up with the mechanical pump, or an EFI conversion?
My AF Classic Model Car Gallery
Old 03-03-2003, 11:01 PM
zangief zangief is offline
Send a message via AIM to zangief
i think that p-man was tought u ment top-fuel dragster rail cars
but u can use small piece of styrene for the rail and phone cord wires for the wiring
Old 03-04-2003, 04:02 AM
"P-Man"
:o ..do i feel like a dummy....i thought you were talking about Top Fuel Dragster's :o :o :o
I Need a break from here
Old 03-04-2003, 10:50 AM
this is a pict of what im talking about. this is just the intake manifold.
Murco: This is the set up im going for. But i will be adding NOS jets too.
Old 03-04-2003, 03:16 PM
mike@af's Avatar
I think my idea has been the bast so far. When you say NOS jets to you mean a whole fogger system and injectors?
-Mike
Old 03-04-2003, 05:01 PM
GTmike400: yeah i want to make and install as much of a fogger system as possible. I have a step by step how to for a real car that should lend its self to this project very well.
Old 03-04-2003, 05:10 PM
mike@af's Avatar
A WHOLE fogger system is pretty sweet. I want to make one but im not sure what to use.
Let me know if you need anything.
-GTmike400
-Mike
Old 03-04-2003, 07:03 PM
Jonno's Avatar
Jonno Jonno is offline
Send a message via MSN to Jonno
I have a magazine article on a 1/12 Corvette (highly modified) with those things in the picture that you posted, only in the magazine they are called velocity stacks. I am not sure whether they are the same thing as what you are after but heres what it says in the magazine:
"Velocity stacks have been made up from aluminium tube with netting over the top cut from a discarded razor screen".
Hope this helps.
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
Old 03-04-2003, 08:48 PM
Murco's Avatar
Maximum Car Guy
Well, If you have a lathe the stacks will be easy. If not, chuck a 2"x1/8" aluminium tube in a drill, center the hole on a pointed piece of metal in a vise (I used a .22 bullet), and run the drill at medium speed until the end flares like you want. Polish it while in the chuck with a metal polish. Cut the tube to desired lenghth, make 7 more, and your done with the tubes.
The base is easier! Just make one from styrene sheet to cover the plenum and ports, smooth and attach. The fuel rails can be thin straight aluminum or brass tubes or a syringe, my favorite! Attach the rails to the tubes with very thin solder rolled with a flat file, add fittings, and paint the lines silver - looks like perfect braided lines! Pressure regulators, linkages, crossovers, and fittings can be made with the same techniques.
Foggers would add more complexity that wouldn't really be appreciated on this set-up (hard to see!) but if you want them use thin electric guitar string for the lines (polish them, you'll be amazed!) as they hold a shape the best, make solenoids from sprue slices, and use the "braided-line" trick from earlier. Electrical lines are best made from the braided wires inside of.... electrical wire! The thinner the better.
An intake like this will be appearing on my next project...
Good luck!
Old 03-04-2003, 08:51 PM
Murco's Avatar
Maximum Car Guy
Is this the engine you speak of?
Which magazine did you see it in?!
93 5.2L OEM fuel lines or plastic connector to fuel rail minifredmaus Dakota 2 02-15-2010 02:39 AM
WTT: D16a6/z6 AEM Fuel Rail for a D16y8 AEM Fuel Rail RedRacerCivic Classifieds 0 02-19-2005 09:05 PM
Fuel rail recal and fuel pump preasure regulator waynem451 Aurora 22 09-12-2004 02:06 PM
Fuel Pressure monitoring on stock fuel rail Marasmus Integra 3 03-19-2002 11:37 PM
FS: JDM RWD SR20DE Fuel Injectors and fuel rail ky_infiniti2000 Classifieds 2 12-06-2001 02:27 PM
