Old 04-08-2008, 05:44 PM
Slatcher Slatcher is offline
over heating, well almost
this question is out of curiousity....today i jus did an oil change and i over filled it by about a cm on the dip stick. i took it for a drive (5km maybe) and when i got back i realized that the engine bay was intensly hot inside, i couldnt touch any of the rad hoses, and i white smoke comin out the exsaust ( i have a hollowed out cat) anywayz i just want to know if all that was caused by over filling the engine. oh and i guess its worth noting that when ever i stopped at an intersection the heat gauge would climb but whne i took off again it would resume back to normal.
thanks in advance
Old 04-08-2008, 05:47 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: over heating, well almost
Nope, not from your oil.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 04-08-2008, 06:05 PM
uh oh...lol well then i guess this goes beyond curiosity now i guess. anything i should look out for to mention to u guys?
hm now that i think about it i also mounted my licence plate infront of the rad but thats all i can think of..
btw its a 91 cd hatch cx 1.5l
Old 04-08-2008, 06:31 PM
FrodoGT's Avatar
White smoke would be coolant. Could also just be condensation in the exhaust before startup..but if you let it sit and then stomp the throttle a cloud will come out and itll shoot some water more than likely if the gasket is gone. Also chekc your coolant to see if there is oil in it, and vice versa.
Current project:
Rio Red 91 hatch.
Old 04-08-2008, 10:02 PM
hm well the white smoke has only been around since i got rid of the catillac converter and its not thick its jus always trickling out. no clouds when i takeoff, and when ya really stomp down on the gas, i get black smoke (when i hit the rev limiter, not that i have in a long time or think that its cool to do that i jus have stupid drunk friends that try to drive it).
there aren't and bubbles under the rad cap while its running and i cant smell oil/gas in the rad fluid.
the car runs great idles nice and smooth never misses a beat its just over heating.
i have one other question out of curiosity what happends whne you really over fill your oil. must be a bad thing
anyways thanks
Old 04-08-2008, 10:34 PM
FrodoGT's Avatar
It comes out seals etc because it over pressurizes. And it could also whip it into a froth. The overheating could have to do with the headgasket too. You should do a compression check.
Current project:
Rio Red 91 hatch.
Old 04-08-2008, 10:40 PM
alright ill do that tommorow what is the psi im looking for?
Old 04-08-2008, 10:52 PM
FrodoGT's Avatar
depending on the mileage it will change, but id say over 140. REALLY, your looking to make sure that they are all within like 10 psi of each other.
if you get something like 170 172 145 176 then you have a problem.
Current project:
Rio Red 91 hatch.
Old 04-09-2008, 10:55 AM
well that went bad lol. i got starting from the driver side 110, 170, 140, 120, so now i realize this problem i have to ask can i get away with just replacing the head gasket or should i order more stuff also this is the reason the car is over heating right?
thanks man
Old 04-09-2008, 06:40 PM
FrodoGT's Avatar
I would start with the gasket, its the most likely candidate, could also be valve seals or broken valves..but that usually happens in just one cylinder. But youll see once you get the head off. Youll probably see the break in the gasket and wheres its leakin if thats the case.
Current project:
Rio Red 91 hatch.
Old 04-09-2008, 07:00 PM
is there anywhere where i can get step by step instructions on how to replace the gasket
thanks alot for the info
Old 04-09-2008, 07:21 PM
FrodoGT's Avatar
Helms service manual will do it. you can find them for download by searching google.
Since you will need the torque specs and tightening pattern to do it right.
Current project:
Rio Red 91 hatch.
Old 04-10-2008, 09:51 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
This may help you out (factory service manual)...
http://www.crxpower.net/~silverkorn/...hop_Manual.pdf
2008 KIA Spectra5 SX
2010 Honda CR-V EX
