Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-08-2008, 04:01 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Unhappy I had no idea where to put this, 1996 chrysler cirrus help plz
I tried posting everywhere, and they all suck lol with no replies, so i know here back where my home use to be or still is, maybe i can get some answers
Here is the deal. Its a 1996 chrysler cirrus 2.5 v6
The car will start right up fine. When idleing you can here it miss once in a while. The minute you step on the gas the car just about dies, like its not getting fuel. You start to feather the gas and the rpms go right up just fine. But once you go to drive it, it spitts and sputters bad like not getting fuel.
I do not think its a fuel problems tho. Fuel pressure seems good, what i mean by seems good is because i do not have a pressure checker so i pumped it in a 20 oz bottle. I can fill the bottle up within probably 6 cranks maybe, so good fuel?
I changed plugs, wires, fuel filter, cap and rotor. Distributor was changed 1 year ago with a brand new one due to the car just dieing completly.
Oh also the check engine light is on, but only code its throwing is a multipile missfire code.
Thank you
Eric
EDIT- erased codes the other day, light came back on just trying to drive around the block. Put my code reader on and P0440 pops up. Thats the only code that popped up.
P0440 - evaporative emissions control system malfunction
Would this cause my problem?
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 04-08-2008, 06:48 PM
Talon69's Avatar
Re: I had no idea where to put this, 1996 chrysler cirrus help plz
Here this will make it easier for you all.
A video
http://s18.photobucket.com/albums/b1...ent=cirrus.flv
Current Cars
Old 04-09-2008, 10:11 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
EGR Valve, and yes it can give really bad idle problems.
***EDIt***
Watching that video, seems like your valve is clogged and shot to hell. I would say get a new one, if not, just clean this one up.
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 04-09-2008, 11:17 AM
Talon69's Avatar
***EDIt***
Egr valve is working properly. I assume, it is moving freely back and forth like it should when giving it gas. Not stuck if thats what your thinking?
Current Cars
Old 04-09-2008, 11:42 AM
JoeShmoe's Avatar
I would still, pull it off and clean it up a bit. That or you have vac leak around that are IMO.
Old 04-09-2008, 02:26 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Did you change your PCV valve? As simple and silly as that sounds, that solved the exact same problem my Firebird had for a while... Worth a shot since a PCV valve is like 2 dollars and 2 minutes to replace. lol...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 04-09-2008, 02:27 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
I would be checking different sensors. It also could be a spark problem. The plugs maybe not be firing well enough to ignite the fuel under load.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-09-2008, 02:41 PM
JoeShmoe's Avatar
Just thinking out loud, pcv and maf.
Old 04-09-2008, 03:21 PM
Talon69's Avatar
I just got home from work, going to try some different stuff and let you know.
also forgot to mention, the studdering started doing it little by little. Would only do it once in awhile going down the highway. Now it is no bad you cannot really even drive it.
Current Cars
Old 04-09-2008, 03:24 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
That sounds like the same exact thing as my bros truck. And it was the spark plug wires. But those are new. But your symptoms are exact as his.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-09-2008, 04:07 PM
Talon69's Avatar
Well, new pcv valve, took egr vavle off, no build up, valve moves nice and smooth with no play, not rotted, falling apart. The vacume to the egr is good. Car still f#@cked up .
reading the book to see what sensor is what.
Current Cars
Old 04-09-2008, 04:13 PM
Talon69's Avatar
even tho i do not have a fuel pressure gauge checker. All i did is what was i said above. Now this is what someone else said on yahoo questions about my issues.
The fuel pump needs to be able to maintain 45 psi in order for the system to work properly. With no load on the pump it will still move lots of fuel but if the pump is weak it won't build the pressure needed. If you can, check the fuel pressure.
Also i did some reading, the MAP sensor could cause my problems? When i unplug the sensor while car is running i see no difference in engine. Maybe its bad?
Current Cars
Old 04-09-2008, 05:15 PM
Talon69's Avatar
Ok, update. MAP sensor is good, works fine, obviously TPS works fine checked that to.
I did notice when the car sits all day and is completly cold it just about runs normal with almost no studder, but the hotter the car gets the worse the problems gets.
Current Cars
Old 04-10-2008, 07:55 AM
Hmmm... This is strange indeed... I can't think of what else it could be really... ECU problems maybe?
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 04-10-2008, 08:42 AM
JoeShmoe's Avatar
Wow, this is racking my brain. Is your MAF good? If it is then I don't think the ECU is out of the question.
Wait......evaporative control system? Do our cars have a black canister that is hooked out the emissions? A carbon canister I think its called? Can someone correct me?
***EDIT***
