Go Back   Automotive Forums Car Chat > Buick > Roadmaster
Old 04-08-2008, 11:22 AM
kharr kharr is offline
Abs
I Have A 95 Roadmaster. The Abs Light Comes On For A While Then Goes Out For A Bit, Brakes Seem To Be Fine. Get In And Start It, It Comes On And Stays On, By The Time I Get To Where I Am Going It Might Be Out Or On.
Old 04-08-2008, 05:41 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Abs
This could be one of the wheel sensors, or it could be many other problems to numerous to mention. The only way to narrow-down the problem, is with an ABS capable scanner. Even then, the scanner DTC’s will only point you in the right direction and might not identify the exact cause. Most brake shops have an ABS scanner and can read the codes for you.
