Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 04-08-2008, 12:40 AM
fl0bby fl0bby is offline
94 Thunderbird A/C and knocking noise
Hi all I am new here and need some help on a couple things.
First off when i start up my car there seems too be a loud knocking noise coming from behind the stereo. It started occasionally when my car was cold, and then began all the time when driving it cold or starting. Although sometimes it does turn off it seems after the car is war.
Second my A/C doesn't seem to work and i would like to get it working before summer. It blows out air and thats all. My heater works great. Should i see a a/c specialist to fix the problem or can i fix it personally?
Old 04-09-2008, 03:48 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: 94 Thunderbird A/C and knocking noise
Welcome to the forum fl0bby. As for the knocking sound, I would suggest raising the hood and looking in the engine comparment to see if the noise is coming from there. This is a hard question to answer without hearing it.
The air conditioner may have lost pressure due to a leak. You could buy a kit that includes some freon with dye to put into the system and a black light to look for leaks. If you don't have the correct equipment to service an air conditioner then I would highly recommend taking it to a shop since to charge a system correctly, it needs to be evacuated with a vacuum pump before charging.
The Original 97Bird
Old 04-14-2008, 06:31 AM
reino134 reino134 is offline
Send a message via AIM to reino134 Send a message via MSN to reino134 Send a message via Yahoo to reino134
Is the knocking when cold you are refering to, more of a ticking sound? My 94 3.8 ticks when it's cold then goes away when it warms up. I went as far as tearing off the top end and replacing the lifters and it still ticks when cold. Spent alot of money and time trying to do away with this irritating noise and have yet to get rid of it! If you locate it, post a reply and let me know what it was
randy
Old 04-27-2008, 03:16 PM
tinner105 tinner105 is offline
On the AC problem..
start with the basics...
does the compressor engage?
has it been converted to R134a ?
here's a test thingy
Old 04-27-2008, 03:17 PM
here's the last section
Old 05-05-2008, 09:48 PM
Thanks for the replies guys. tinner105 your pictures seem to change every time i refresh the page?
Sorry for the late reply.
Old 05-05-2008, 09:57 PM
send me your email addy in a PM and i'll email them to you.
tony
