Some Help Plz
HI GUYS WELL I HAVE A 1996 BURB 2WD 5.7
ALL THE WINDOWS WORK BUT JUST FROM THE DRIVERS DOOR CHECK ALL THE FUSES THAY ARE ALL FINE TOOK ALL THE SWITCHS OUT TO CHECK PLUGS ALL IS GOOD SO I UNPLUGED THE PASSINGERS SWITCH AND TRYED AGAIN FROM DRIVER DOOR AND IT DID NOT WORK PLUG BACK IN AND IT WORKS AGIN BUT JUST FROM DRIVER DOOR AND I UNPLUGED LOCK AND UNLOCK SWITCH IN THE DRIVER DOOR JUST TO SEE IF THIS WILL WORK BUT NO IT DID NOT SO I AM AT LOST SO CAN SOMEONE HERE HERE PLZ
Re: Some Help Plz
It sounds to me that possible be your lock out switch in the driver side door is not working. Have you by passed it? Or replaced it? Dave
Re: Some Help Plz
i unpluged it and it still is not working
Re: Some Help Plz
You need to bypass the lockout switch (paper clip between the two terminals). When it's just unpluged, it's the same as being in the lock position, the switch closes to allow the windows to work.
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
Re: Some Help Plz
ok cool will try that and get back thanks guys
hope that works
Re: Some Help Plz
WELL I BYPASS THE SWITCH AND IT WORKS THANK YOU GUYS
