sputtering question
alright need some help...
when i bought my Civic i was told that it will need a distributor because it still has the same distributor from when he swapped the motor...in the mornings and sometimes during the day the car starts to sputter, more noticable in first and second gear and even while cruising it can feel it sputter some...the guy i bought it from is an 11yr honda tech, but his cutting of the springs leads me to question some of the stuff he say...any help
The name's Adrian 1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills 2006 G35 Coupe 6MT - Stock 2011 CR-Z - Stock |
Re: sputtering question
maybe fuel filter or injectors? |
i haven't done anything yet..figure i'd ask here 1st...mabey that's what is getting me horrible gas mileage
when my distr.was going out it would sputer or hesitate while cruising. kind of felt like it wasnt getting gas for a fraction of a second. dont know if that helps or not
went outside and checked the ecu throwing these codes: Code 4 (4 flashes) Crank angle sensor Code 8 (8 flashes) TDC position (top dead center) timing
Thats ALL distributor mang
Cheap, Fast, Reliable..Pick two ![]() Current project: Rio Red 91 hatch. A6/Z6 build, Hondata S300, Tokico illumina/Ground Control. "I'd rather run 12's on steelies than 15's on rotas." |
so he was right...just wanted to be sure b4 i go out spending $$$, now to find an LS distributor
You're running obd0 right? Didn't they only make obd0 integras with the b18a for a couple of years? GL, Blu!
2008 KIA Spectra5 SX 2010 Honda CR-V EX |
yeah it was way more noticabe under accelration. but when i got up to speed it would still do it just on a much smaller scale
it's OBD0 and i'll let you guys know what happens after i replace the distributor
well the problems went away and now they're back...went to start the car and got nothing...no spark no engine trying to turn over, nada...so i'm ordering a distributor right now...also found out it's the same dizzy that was on the original a6, so only 2 bolts are lining up and it seems to have been leaking oil while running, probably the reason there are no traces of oil in my driveway
![]() so this is the one i'm ordering http://cgi.ebay.com/ebaymotors/BRAND...QQcmdZViewItem
oh and i furgre that's why i'm running ruch...put my had over the exhaust at idle and i get black powder on it
Get a Distributor King. Not much more expensive than that one and from the picture, a lot better quality. Its what I got when I replaced mine and I'm very satisfied with it. They also run upgraded ignition modules since thats one of the weak points in the distributors.
I picked mine up off of eBay as well, shouldn't be too hard to find.
Tony 91 Civic Sedan DX - Stock 287k Miles |
