Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 04-07-2008, 05:57 PM
Gatorac's Avatar
Gatorac Gatorac is offline
Rear sway bar for the GTRA
I have installed a rear sway bar. It's exactly like the one on the GTS car shown here.
(This picture is lifted off of www.wirewheel.com )
The mounting brackets and holes where already in my car. You will need to trim the sway bar arms and drill some holes in them. Everything else is bolt in.
Here's a material list
1 3/4"x36.5" Speedway Engineering sway bar. PN 607-4 (the only had a 36" bar in stock so I got it. It will work but the 36.5" will be better)
2 Speedway Engineering aluminum sway bar arms. PN 616
2 3/4" locating collars PN 605C-75
I bought the above from www.hrpworld.com
2 3/4" rod ends
4 3/8" rod ends
4 3/4"/16 nuts
2 3/8" 24 coupling nuts
4 3/8" 24 jamb nuts
4 3/8"x1.5" grade 5 or 8 bolts, nuts and washers.
I got the rod ends from www.thebigbearingstore.com
The nuts and bolts came from the local hardware store.
Total cost was about $215.00
I'm headed to Sebring this weekend with Chin. I'll let you know how it performs.
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Backdraft Racing Cobra #930
92 Miata "LemonDrop"
Saturn V Rocket Miata Crapcan #81
99 Miata daily driver.
Old 04-07-2008, 11:12 PM
Blue Streak 21's Avatar
Blue Streak 21 Blue Streak 21 is offline
Re: Rear sway bar for the GTRA
Awesome. I've been hoping to pick up a rear bar.
Look forward to hearing how it works on the car. Enjoy Sebring!
Jerry
1999 Panoz GT-RA
Old 04-08-2008, 07:01 AM
glenbinegar glenbinegar is offline
Thumbs up Re: Rear sway bar for the GTRA
Hi Jim,
great run down of the parts. Looks just like the set-up on our GTWC car. Will look for you at Sebring. Glen
Old 04-08-2008, 02:00 PM
Gatorac's Avatar
Originally Posted by glenbinegar
Hi Jim,
I'm sure you'll see me as you pass me. I'll be running the street tires again.
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Old 04-10-2008, 07:13 PM
Squerly's Avatar
Squerly Squerly is offline
Must be a private joke? Why would you be running street tires on a car that isn't street legal??? Or did I miss something?
Squerly
Old 04-10-2008, 08:24 PM
Gatorac's Avatar
Why would you use race tires if your not racing? Or did I miss something?
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Old 04-11-2008, 05:40 PM
David Eastman David Eastman is offline
The School cars came with street tires.
David
Old 04-13-2008, 08:15 PM
Gatorac's Avatar
Re: Rear sway bar for the GTRA ***Performance report from Sebring***
Well, I'm back after 2 days on track at Sebring with Chin Motorsports. The rear sway bar made a noticeable difference. At first I set the new rear bar on the softest setting. Springs and shocks are as delivered. The push was gone. I did have some over-steer though. It was a bit unnerving at times. The car may have been faster, but it was not as much fun to drive. I no longer had the front tires scrubbing across the track.
I then set the front bar from the softest setting to the firmest. This dialed out the unpredictable over-steer and made the car very neutral. Instead of scrubbing the front tires at the limit, the car would go into a 4 wheel drift. Hammering the throttle on and off to make it turn was no longer required.
All and all I say it was very worthwhile addition. I haven't been keeping lap times so my analisys is all SOTP. I'll know more in 3 weeks. David is coming to Sebring with his GTRA. We'll run nose to tail and make some comparisons.
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
