Old 04-07-2008, 03:21 PM
socko42 socko42 is offline
ATF change
Some questions abouting changing ATF in the 6 cyl. engine:
1. How much fluid total does the transmission hold?
2. how much comes out when you drain?
3. since you don't get it all out when you drain, is it ok to fill with synthetic ATF (you'll be mixing syntethic with the regular stuff)?
Old 04-07-2008, 08:05 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: ATF change
Welcome to AF.
Your trans hold 9-10 quarts but when you change your fluid you will only get 7 quarts out of it. No way to clear it all out with out disassembling the trans.
It is ok to mix the two types of fluid as long as the syn says its OK to mix.
Here is a link for the trans fluid & filter change.
http://www.automotiveforums.com/vbul...d.php?t=700903
Hope that helps!
1999 Grand Am SS 3.4 OHV
Old 07-25-2008, 02:27 PM
Re: ATF change
Didn't want to get covered with fluid when dropping the pan, so I bought the Wix tran. kit (with supposedly lifetime gasket, filter etc.) and 7 qts. of Dexron VI ATF and had my local garage hoist it up and do the dirty work. But the mechanic said it only takes 4 qts. and only uses that much to drain and refill, and in checking the view plug he said it was full. What gives?
