Old 04-07-2008, 11:30 AM
blizzardoftheozz blizzardoftheozz is offline
1985 Cavalier won't start after tune up
I was given an 1985 Cavalier not long ago and it was running decent but needed a tune up. It would fire up on one turn of the key but ran a little rough. It had set idle for about 2 weeks before the weather finally got good enough for me to change the plugs, plug wires, rotor and distibutor cap.
After everything was changed out I went to start it but it wouldn't start. Chevked everything out 3x over but still no go. I pulled the #1 plug and put it in the plug wire and turned the car over to see if I had spark...and I did.
Not sure what else to do. Any suggestions would be welcome.
Thanx
Old 04-07-2008, 01:13 PM
yhandor's Avatar
yhandor yhandor is offline
Send a message via MSN to yhandor
Re: 1985 Cavalier won't start after tune up
Classsssiccc
Old 04-07-2008, 03:13 PM
DAUGHTERISIS313's Avatar
DAUGHTERISIS313 DAUGHTERISIS313 is offline
Thanx
Battery/Alternator?
Old 04-07-2008, 10:36 PM
The battery is strong. Car turns over but just won't start.
Old 04-08-2008, 11:51 AM
muff34 muff34 is offline
Change the fuel filter, check your fuel pressure. Fuel pump could be going south
Life Is A Highway ,Enjoy The Ride
