Old 04-07-2008, 10:37 AM
d94 d94 is offline
Exclamation engine light on after using seafoam
so i put seafoam in my car about a week ago, via the oil pan, engine, and gas tank.
and right after i turned on my car the engine light went on..there was tons of white smoke meaning the seafoam did its thing..but the engine light's been on! However, my car has been running just fine. tomarrow im going in for some free warrenty work at the dealership, and they're replacing the oil, spark plugs and a few other things..could that take care of it? or would anyone have an idea of what it could be...?
Old 04-07-2008, 11:09 AM
somick's Avatar
somick somick is offline
Re: engine light on after using seafoam
We need a little more information: what car you drive, miles on your odometer, maintenance history.
I do not think that Seafoam caused your MIL to come on. You need to read a code and go from there.
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 04-07-2008, 12:55 PM
d94 d94 is offline
Sam
Woops my bad i thought i had the info in my sig! guess not
its a 1995 accord v6 with 106k miles. nothing special has been done to it, i got it off my aunt with 95k miles and she pretty much babied it, shes also the original owner and bought it new way back when. do you think they'll check for codes when i go in to do warrenty work? or how would i go about reading the code?
thanks!
Old 04-07-2008, 04:13 PM
somick's Avatar
I am a little confused about "warranty". It is 95 and suppose to be out of warranty, unless you bought it with some other company.
Now back to your code. I think any garage can check your codes but I doubt they will do it for free.
You can do it yourself.
Remove your glove box. You will see a blue connector with two wires. I think this connector is pluged somewhere on the wall. Pull it up. You need to short this connector with something (paper clip comes handy here). Then put your key in the ignition and turn it to ON (ENGINE NOT RUNNING). Count short and long blinks on the MIL. That will be your code.
If you want more details about this procedure you need to get Haynes repair manual. The procedure is there. If you do not want to buy a book, look for it in the library.
Good luck,
Sam
Old 04-13-2008, 07:37 PM
stang805's Avatar
stang805 stang805 is offline
Send a message via Yahoo to stang805
It more than likely pissed off a sensor to have the smoke adn what not goin on there, just go have an autoparts store reset the code and it probably wont come back. if it does then look up the code and find out what might actually be causing it.
Old 04-17-2008, 11:24 AM
somick's Avatar
He drives 95 Accord. Automotive store cannot reset his code.
Sam
Old 04-17-2008, 11:48 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
If you need to reset it yourself, pull the ECU fuse out for a while. you could just disconnect your neg battery cable, but then youll have to re enter your radio presets
Old 04-17-2008, 08:20 PM
Hondatech44's Avatar
Hondatech44 Hondatech44 is offline
the light turns on for a reason...not because you put seafoam...dont use that stuff...i wouldnt...if you want to clean your fuel injectors let honda do it......disconnect your battery for 30 seconds to clear all memory in you computer...hope you have the radio code!!
Old 04-22-2008, 06:00 PM
StealthSonic StealthSonic is offline
One possibility, your O2 sensors might went out while the chemical is going through the exhaust. The silver inside the sensor might be contaminated and unable to function; therefore, you get engine check light. I have never use seafoam before. What exactly is it?
You do need to post the error code so we can find out for you.
http://importfan_accord.homestead.com/files/New_Page_Accord.jpg
Old 04-24-2008, 11:45 PM
stang805's Avatar
just reset it and see if it comes back
