Go Back   Automotive Forums Car Chat > Cadillac > General Discussion
Old 04-07-2008, 08:18 AM
dhspring dhspring is offline
Rough idle on cold start. 98 Deville
Can anyone tell me why my 98 Deville, 4.6L Northstar runs rough on cold start, it does this for a couple minutes until it gets warmed up then evens out and idles okay. I have 125,000 miles, recently changed, plugs, wires, EGR valve, fuel and air filters. There are no engine lights on. It almost seems like a plug or plugwire misfire and runs pretty rough, until it warms up. This just started happening, hope someone has a suggestion, thanks.
Old 04-07-2008, 10:20 AM
maxwedge maxwedge is offline
A990 racer
Re: Rough idle on cold start. 98 Deville
Look inside the vacuum hose at the FP regulator for signs of raw fuel., they are known to leak and this is one of the symptoms.
Old 04-08-2008, 12:14 PM
Maxwedge:
Thanks for the tip, I checked the vacuum hose to the fuel pressure regulator, no raw fuel, but whatever it did it seemed to fix the problem, the regulator was replaced about 2 years ago. Thanks so much, I think that fixed the issue!
