Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-06-2008, 11:19 PM
n2play1 n2play1 is offline
Do RS9000XL (RS999214) fit non-lifted 98+ rodeo's
yes I know it may be overkill for non lifted non heavy off road use but I figure why not if i got the money to get them now and it looks like they got the 3 get 1 free deal going on right now, if I'm looking at the right shock ad's correctly!!!!!!!!
I believe the new style shocks have a bigger bore size.....
anybody have them on non lifed rodeo's......
Old 04-07-2008, 10:55 AM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
Re: Do RS9000XL (RS999214) fit non-lifted 98+ rodeo's
The 99214 would be the size for the front and would be the same if there is a lift or not. The front shocks use the same size. 99136 also works on the front with some trimming of the shock bushings. I dont know what ones the rear would use for non lifted.
If the diameter is larger you might run into some issues of the front sway bar rubbing on them. I have the older 9000x and they dont rub but its kinda close. You would also need to pay close attention to the rear shocks and probably shim them out. I had to use 2 1/2" washers behind the lower mounts on my rear 9000x or they would rub on the axle mount.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
