Go Back   Automotive Forums Car Chat > Honda > Integra
Old 04-06-2008, 04:37 PM
RounderAdak RounderAdak is offline
Integra Motor Question.
I need to find out what happened to my motor.
Symptoms are : Oil in the cooling system - Burning oil out of exhaust, slight knocking, and a rough idle (engine somewhat sputtering).
Let me know please.
Old 04-06-2008, 09:57 PM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
Re: Integra Motor Question.
head gasket.................
Old 04-06-2008, 10:10 PM
So do you think it would have damaged the main head?
Say, if i got a new gasket, and then placed the head on a different block, all would be well, right?
Old 04-07-2008, 10:36 PM
wiseguy01's Avatar
possibly as long as they go together but i know that if water gets in the oil or oil gets in the water the only place it can get in is the head gasket so double check it also a compression check on each cylinder would let you know what area the head gasket has failed or where the leak is also if you ran it long enough for it to knock then engine damage is eminent check the lower end like the main bearings for scoring and check valves too
Old 04-10-2008, 11:32 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Check the head and block for warping. if there is none, youre good with just replacing the headgasket (and an obvious coolant and oil flush).
