Old 04-06-2008, 12:35 PM
xavier h xavier h is offline
97PA voltage drop
148K
When I hit the brakes the lights dim for a moment. The alternator/regulator is new and I had it checked out. The battery is also good but not charging the way it should? Any ideas? Corroded wire?
P.S. Did the upper manifold change, what a job. Change the valve cover gskt's, plugs/wires and thermostat. No more leaks or engine odors! Runs like a top.
Thanks
Old 04-06-2008, 02:37 PM
maxwedge maxwedge is offline
A990 racer
Re: 97PA voltage drop
A split second slight dimming of lites when any load is applied may not be abnormal, check the alt output under load to be sure.
Old 04-06-2008, 07:11 PM
Do the crankshaft and camshaft sensors show trouble codes when they go bad?
Old 04-08-2008, 01:09 AM
dksram
Guest
Posts: n/a
Lightbulb Re: 97PA voltage drop
Normally the sensors will throw a code.Mine did not throw a code.
The dimming effect you describe sounds like the alternator.The cables could be corroded badly and cause lots of problems.Never really liked side mount battery posts.
I had the same thing happen and that fixed my problem.
I never noticed any light dimming with the sensors going out.Just rough idle.
Old 04-08-2008, 06:42 PM
A990 racer
Sometimes.
