Go Back   Automotive Forums Car Chat > Ford > Probe
Old 04-06-2008, 09:34 AM
Metalomat087 Metalomat087 is offline
Question 1993 Probe Trans/clutch problem
Having a problem with my trans. While traveling at 55mph. my trans just seemed to disengage. It will go into gears and speedo will move with it but no power getting to wheels. Any ideas?
Old 04-06-2008, 09:56 AM
Question Update
After having the car towedfor $100 and sitting overnight, I started it up and everything seems to be fine. I am afraid to drive it and have it happen again. Anything i should be looking at, because I have no clue?!!
Old 04-19-2008, 09:02 PM
FORDGUY09's Avatar
FORDGUY09 FORDGUY09 is offline
Send a message via AIM to FORDGUY09 Send a message via MSN to FORDGUY09 Send a message via Yahoo to FORDGUY09
Post Re: 1993 Probe Trans/clutch problem
what engine and type of tranny do you have? more info helps get dio's
1997 Honda Accord
2003 F250 6.0 ps cclb
2016 jeep patriot
Old 04-23-2008, 11:19 PM
The problem was solved. turns out whomever installed the halfshaft overtightend the axle/hub nut and pulled the shaft from the trans. A new ring clip on the trans side and WALA!! problem solved. But to answer your question... It has a 2.2 stock with a 5 speed manual. Now i'm having problems with the caliper on the same side sticking and burnin the brakes. never ending!
