Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 04-06-2008, 05:09 AM
AlexDuran AlexDuran is offline
97 Civic Engine Problem (bent valve?)
Hey everyone,
Just getting some input, figured this would be a somewhat common question though I was surprised not to find much about it in my threads search.I have a Honda Civic 97 LX, today while on the highway it sputtered to a stop. This was not before it made some serious clanking noises. There was an oil leak (it happened fast apparently), and one quick observation from the towing guy said a valve was bent (pretty much all the oil was gone), and that the engine may need to be replaced. Of course I started doing research about it when I got home, some people talking about it on line say it isn't over for the engine and it is just a bent valve (can be repaired), others say it is toast. Anyway, any thoughts or input are greatly appreciated. For a used engine it looks like about 600-700.00 at the lowest, another 1000.00 or so for labor. Would rather the current engine be fixed at a lower cost than getting a new one...
Alex
Old 04-06-2008, 11:40 AM
wiseguy01's Avatar
wiseguy01 wiseguy01 is offline
Re: 97 Civic Engine Problem (bent valve?)
bent valves can be repaired so long as the damage stays on the top end if it proceeds into the bottom then rebuild is cheaper way to go but first fins out wht the valve bent before you do any motor work possible timing belt because ive heard of people replacing the motor three times and all three the valve bent again so check that first
Old 04-06-2008, 12:38 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
If you ran out of oil, you prolly burned out your rod bearings, which would explain the "clank", then you prolly roasted you piston rings... losing all your compression, hence the stall
