Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 04-06-2008, 01:03 AM
vzfox vzfox is offline
Question '92 Bronco full size...headlight bezel removal
the title says it all.....how the heck does the headlight bezel come off?
Old 04-07-2008, 05:41 PM
jfisher67846 jfisher67846 is offline
Re: '92 Bronco full size...headlight bezel removal
It's the same as a '92 ford 150, this is how I took off mine, take your grill off, take the header panel bolts off but not the bolts to the radiator support, and you'll have to take the little piece of metal between the bumper and grill, go through your wheel wells for that. but watch everthing you do, there should be two (2) bolts on each side of the corner headlight on the header panel to take off, then you'll have to be carefull not to break your header panel like I learned, this should give you somthing to do for a while. e-mail me at [email protected] if you have any other questions.
Old 04-13-2008, 05:18 PM
thanx....i figured it out. your reply helped, but i didnt have to take the grill off. i have skinny enough arms and hands that i was able to reach in from behind and get the two nuts off. i dont know why ford decided to make it near impossible to change a light bulb....ughhhhh.
