Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 04-05-2008, 06:14 PM
bryaninontario bryaninontario is offline
Question intrepid cradle mounts
Does anyone know if the cradle mounts are accesiable to undo or does it require cutting holes in the floor to get at the nut on the top of mount? I know that some fords are like thatmine are falling right out of the car almost! Anyone advice would be appreciated greatly! Thankyou!
Old 04-05-2008, 08:37 PM
tempfixit tempfixit is offline
Re: intrepid cradle mounts
What year and engine?
I assume you mean motor and transmission mounts by cradle mounts?
Old 04-06-2008, 10:43 PM
Diesel nut's Avatar
Diesel nut Diesel nut is offline
No you don't have to cut holes in the floor. Just simply remove the bolt that holds them and you will need to use a floor jack and let the cradle down a little bit to pull out the top part of the mounts. This should work with little trouble, It took me about a half hour to change all four mounts on a '97 trep.
