Old 04-05-2008, 03:31 PM
citydragon citydragon is offline
Drum Brake Removal
1995 Sedan 1.3
I wanted to check the thickness of my brake shoes today. I could not remove the drums. I removed the two retaining screws and could not budge the drums. I tried relieving the tension by pushing through the small hole on the back with a small screwdriver also. I believe on this model there is no need to remove the hub nut.
I hit all around the drum edge with a hammer and still no go.
I have removed drum brakes on other GM cars and they would just slide right off. These are stuck on. Am I doing something wrong?
Old 04-05-2008, 06:19 PM
hot_sd hot_sd is offline
Re: Drum Brake Removal
I opened up the drums on mine a couple or years ago or so to check the shoes and as I recall they slid right off. Maybe the drums have corroded. Try some penetrating oil and see what happens. I guess you can try a puller - I think the FSM has listed a puller tool for the job but it has been a while now since I did the job so I cannot recall exactly.
Old 04-06-2008, 07:03 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Did you release the emergency brake? Not hinting that you are a dummy, I've done that myself. Rear drums were done both ways on the 95 and newer Metros. Some have a separate hub and drum which comes off the way you describe. Some have the hub and bearings built into the drum and you have to remove the center nut. If you have the two countersunk screws between the lug nuts, I'm pretty sure you have the separate hub and drum. There is a method of fishing around with a screwdriver through a hole in the backing plate to release the self-adjuster, but until you've had it apart and looked at the mechanism closely, it's almost impossible to visualize how to do this.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 04-06-2008, 02:44 PM
Yes, that's a good point - forgot about the 2 styles. I believe you have one style or the other depending on whether the car has ABS or not. Mine does not have ABS.
Old 04-06-2008, 05:01 PM
Originally Posted by citydragon
1995 Sedan 1.3
Thanks for the replies...My car does Not have ABS. I've posted a picture below of the drum with the retaining screws removed.
Old 04-06-2008, 05:54 PM
inafogg inafogg is offline
hello, the other 2 screw holes are for removal,get 2 self tapping bolts screw them in to push drum off.Good Luck
Old 04-06-2008, 07:57 PM
brivers brivers is offline
I believe the other two holes should already be threaded
Old 04-06-2008, 08:50 PM
You need to take that cap thing in the middle off first or the hub will not come off. Use a chisel or similar to pry it off. Don't try pullling it off without removing it first.
Old 04-07-2008, 11:22 AM
sorry hot,but no need to remove dust cap drum will slide over!!Good Luck
Old 04-07-2008, 10:46 PM
I rechecked the FSM to see what the deal was on this. Based on that as well as my recollection of the procedure - I believe the center spindle nut holds the drum in place. You need to take off the dust cap and check but I think you will find the spindle nut is holding the drum in place. I recall having to remove the spindle nut.
Here is the info from the FSM - hopefully that will help you.
Old 04-07-2008, 11:46 PM
Wow! Thank you!, that is good information...Just to add to the confusion...Are the FSM instructions referring to the 4 door sedan or 2 door hatchback?
The pictures below are from Rockauto and the drums between the sedan and hatchback are somewhat different. The hatchback drum looks like it is held in by a spindle nut.
This is the Sedan Drum
This is the Hatchback Drum
Old 04-07-2008, 11:58 PM
The FSM does not differentiate between sedan and the hatchback. I think what Rockauto is mistakenly showing is the ABS and non-ABS drum. The ABS drum appears to come right off and there is no dust cap unlike the non-ABS drum - at least that's what I can see from the info in the FSM.
Old 04-08-2008, 04:54 AM
Woodie83's Avatar
The picture citydragon posted of the drum on his car is obviously a separate hub and drum setup. As I said before, IF IT HAS TWO COUNTERSUNK SCREWS BETWEEN THE LUG NUTS, THE HUB DOES NOT COME OFF. If the hub and drum are one peice what possible purpose would those two screws serve?
Woodie
Old 04-08-2008, 11:39 AM
metro_roy metro_roy is offline
You might also have to back off the emergency brake cable adjustor.
Old 04-09-2008, 12:03 AM
91Caprice9c1 91Caprice9c1 is offline
LOL so true... Woodie's right guys. Do as the man said, find a screw that matches the THREADED HOLES in the drum, and crank it down til the bastard pops off. This is simple stuff guys. opcorn:
-MechanicMatt
1996 Caprice 9c1 - Daily Driven Project Car
1993 Geo Metro - Accident
1991 Caprice 9c1 - Destroyed
