Old 04-05-2008, 02:04 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Bolt Removal
I have a bolt stuck in my spoiler. It's a banana wing from a 91' Stealth. The head snapped off when I was removing the rear wiper. I bought an easy out and gave it a try today. Well, the easy out broke if in the bolt. I've tried drilling it out with no luck. So, I'm left with two options.
1. Take it somewhere to have it fixed.
2. By a new support.
I don't know what kind of place to take it to that could fix it and I don't know where to get a support as the Dodge dealer has no clue as they only show the wing, grommet, and bolts.
Any ideas where I can go from here?
Old 04-05-2008, 02:45 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Bolt Removal
A broken easy out SUCKS.
As for the support you may find someone willing to sell you one for cheap off a parts car. If I had any extra bananas (other than the 96) laying around I'd give you one.
Old 04-05-2008, 04:02 PM
Polygon's Avatar
The Red Baron
Re: Bolt Removal
That's what I'm hoping for. I'd even buy all three of them in case this happens again. I certainly don't have any bits that can even put a dent in that easy out. So, Hanz or Jason if either of you two can get me some banana wind supports I'd be very grateful.
Old 04-05-2008, 06:07 PM
inafogg inafogg is offline
Re: Bolt Removal
you need to use a carbon steel bit.if you have a machine shop around you give them a call.they should be able to help with removing bolt/ez-out
Good Luck
