Go Back   Automotive Forums Car Chat > Dodge > Avenger
Old 04-05-2008, 11:32 AM
ttaylor61 ttaylor61 is offline
97 Avenger relays
My daughter started having problems with her Avenger occasionally not starting a few months back. Always ran fine after it started. To make a long story short, I accidently discovered the problem was one of the 3 relays mounted on the driver's side fiewall. When the car will not start all you have to do is tap on the relays and it starts right up.
Today I replaced the fuel pump relay which is the far left relay. The car started multiple times and I thought I had it fixed. Tried to start it one more time before I closed the hood and it would not start. Tapped on the relays and it started right up again.
The question is, what are the other 2 relays? They both have part number 83159 stamped into the top. It's hard to find the part when I don't know what to call it. One more thing is has the 6 cylinder engine.
The Following User Says Thank You to ttaylor61 For This Useful Post:
Mark72 (11-18-2011)
Old 04-08-2008, 11:32 AM
jpb53 jpb53 is offline
Re: 97 Avenger relays
The middle relay is the ASD (automatic shut down). The far right is the EATX (Electronic Automatic Transmission)
Old 11-18-2011, 07:57 PM
Mark72 Mark72 is offline
Awesome, This just worked for me.
98`Avenger 2.5 Thanks
