Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-05-2008, 12:35 AM
0-60IN2 0-60IN2 is offline
Check engine!!!?!?
I was cruisin around tonight and the check engine light just decide to come on.My car has been runnign rich so maybe the o2 sensors are fouled. But my car is boosting to 20psi. When i floor it and se it go to 20psi i let off. I usually dont let it get that high. I usually only go to 10 psi. But yeah I mean I hate that its on!!!
1996 GSX - Apexi N1 exhaust and downpipe,NGK 10.2 mm plug wires,HKS intake,Blitz turbo timer/boost controller
2003 avalanche
Old 04-05-2008, 12:59 AM
Bodack Bodack is offline
Send a message via AIM to Bodack
Re: Check engine!!!?!?
So what? Is there a question you need answered or something? And besides, this is pretty much a double post anyways since you already made a thread about your 20psi boost. I don't post on here a whole lot, but I read just about every day and your threads are getting pretty ridiculous. You should do some searching before you post or at least come up with a question you want answered.
Also, you never said what sort of gauge you were using in the OTHER thread about this problem. Take the car to Autozone to check your engine light.
1993 Honda CBR900RR
1990 Talon TSi AWD - Sold
1990 Laser RS turbo - Sold
1993 Eclipse GS - Sold
Old 04-05-2008, 01:13 AM
Dude honestly, then dont reply ok? I just need help on to why my CHECK ENGINE light came on.....not about the 20psi got that? thank you.
2003 avalanche
Old 04-05-2008, 01:19 AM
You gave no symptoms or details, as you often forget to do in your posts. How could anybody know why your CEL was on just because you were out cruising the streets. It's a commonly known fact that Autozone will do free CEL scans for OBDII cars. The problem is almost always a sensor of some sort. You should always give details if you want a question answered. Or you should ask a question to begin with. Good grief
1993 Honda CBR900RR
Old 04-05-2008, 01:26 AM
Well in Canada we dont have an autozone.
2003 avalanche
Old 04-05-2008, 01:29 AM
I'm pretty sure steviek lives in Canada. Ask him
1993 Honda CBR900RR
Old 04-05-2008, 02:09 AM
I have a vaccuum leak somewhere I think ...would that explain why my cars wants to die at idle?
2003 avalanche
Old 04-05-2008, 06:32 AM
ned032002's Avatar
ned032002 ned032002 is offline
If your racing all these super slow cars like Vipers, STi's, and SRT4s, then how are you doing it w/ out going over 10 psi? Are you using muffler bearings? I read a little bit about them and how they can had a whole lot of BS HP!!
Who are you trying to fool in several of your other posts you talk about all these street kills so you are allowing the car up to 20 psi in order to "beat" them.
If you want your CEL problem fixed you could at least post an error code or some symptoms of whats going on w/ the car. And yes a vacuum leak could cause you not to idle worth a damn.
Old 04-05-2008, 09:49 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Even if you don't have an Autozone to check the CEL, you can still do the key-switch test where the CEL will flash a certain number of times revealing what the code is. We can't tell you, hey, your CEL is caused by _THIS_! Although I think we all know what it MAY be. But you have to get it checked.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 04-05-2008, 10:13 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Dude, you car idles like shit bc your BOV isin't recirculated. I dont see that you have any supporting mods to go to 20psi. If you are still on stock injectors your pretty much begging that motor to blow. The ECU may be detecting over boost and that why you get the cel.
We have no idea why the light came on. The only way to find out is for you to get the car scanned. If no place does it free in canada then maybe you should just buy a cheap obd2 scanner. Or if you hook up dsmlink it would tell you.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-05-2008, 10:14 AM
steviek's Avatar
steviek steviek is offline
Unfortunately 0-60 is right we don't have autozone in Canada. I bought my own personal obd2 reader for like100 bucks just for times like this. However, most local shops will run the code for you for free (it just involves plugging it in and pressing a button.) Bodack is right you should definitely give us as much information as you can to help us help you. My first instinct is o2 sensor because you are venting and running really rich. But we can't do anything without the code. Get that code checked for free and we will tell you the possible things that caused it no problem.
Vacuum leaks can be checked by boost leak tests.
Here is a quick link on how to perform them that I made
http://s83.photobucket.com/albums/j2...rent=boost.flv
Ps DSMLINK will read your code for you don't you have that?
Oh yea and Silvr is right and so is David and NEd
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 04-05-2008, 11:22 AM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Get a logger. www.pocketlogger.com
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 04-05-2008, 07:16 PM
ned032002's Avatar
Reading about all the advice that has been given to you 0-60 reminds me of a few lyrics from that song entitled "Everybody is free to wear sunscreen" maybe you should read this and take every word in no matter how corny they sound.
"Be careful whose advice you buy, but be patient with those who supply it. Advice is a form of nostalgia; dispensing it is a way of wishing the past from the disposal--wiping it off, painting over the ugly parts, and recycling it for more than it's worth."
I know that it may sound corny but what I'm trying to say is stop making numerous useless threads when sometimes all you need to do is take the advice that people give you. Re-circulate that BOV and get back at us.
Old 04-09-2008, 12:42 AM
Jsharp Jsharp is offline
well my car runs rich too but i mostly fixed the problem by adjusting the air fuel ratio screw,and my check engine light is always on dont know y,but when i took it to the mechanic and had it hooked up to a computer it read no codes,no errors,no problems it said nothing,so what should i do to fix my car??
Old 04-09-2008, 01:35 AM
steviek's Avatar
what air fuel ratio screw? you mean the BISS? it doesn' work like that
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Closed Thread
