Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 04-04-2008, 06:17 PM
orangebug orangebug is offline
2003 check engine code cooling system
I had the check engine light to come on and the VAG Code is 18613 and it states that it is a Performance malfunction in cooling system. Does any one have more info on this code. thanks
Old 04-05-2008, 02:09 PM
Kirk in Iowa Kirk in Iowa is offline
Re: 2003 check engine code cooling system
This could be caused by a bad thermostat or perhaps a water pump.
The computer looks at how long it takes to reach a certain temp. If the timing is outside a preset range, this code may be thrown. So, you may have a water circulation problem....the water pump or the thermostat.
If you don't have a circulation problem, you may have a coolant temp sensor problem. The coolant temp sensor is very easy to change. I think the newer coolant sensor has a green body, the old one black.
Let us know what it is....
Kirk
Old 04-05-2008, 09:28 PM
bratt bratt is offline
does your temperature guage still work? are your fans working when it gets hott? does it overheat?
Old 04-06-2008, 09:36 PM
The cars blue coolant light goes off about the same driving distance that it always has and it doesn't seem to be overheating at all. I will look into the coolant switch. The water level all seems to be normal also. Still sounds like a mystery as to why it would be causing such a fault. The VAG said that it was an intermittent fault. Thanks for assistance, I will keep in touch.
Old 04-23-2008, 08:22 PM
I took the car to our local dealer and they ended up replacing the engine temperature sensor.
