Old 04-04-2008, 05:16 PM
atv087 atv087 is offline
Send a message via AIM to atv087 Send a message via Yahoo to atv087
86 escort no spark
86 escort carburated. No spark replaced coil. Still no spark. what feeds the coil on this car?
*Link removed by Moderator* THE BEST CAR RESOURCE YOU WILL EVER FIND!!!
Old 04-05-2008, 08:45 AM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: 86 escort no spark
Check your distributor parts... contacts may be worn.
Old 04-05-2008, 04:44 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Ignition switch?
Old 04-05-2008, 06:44 PM
rhandwor rhandwor is offline
Use a 12 volt test light put it on the coil positive if you have 12 volt put it on the coil negative have somebody try to start the car if it doesn't blink replace the pickup in the distributor. If it blinks pull the module and take it to Advanced or Autozone and ask for a free test.
Old 04-07-2008, 04:56 AM
tripletdaddy tripletdaddy is offline
Ditto on the ignition control module(Ford TFI module). It fails very often on this vehicle. And one of the symptoms is no spark. Before, no one could test the icm. Was a lot harder to diagnose. I'd just go ahead and pull the icm, have it tested and buy a new one if needed, buy the pickup if not.
