Old 04-04-2008, 03:04 PM
kuhawk kuhawk is offline
Location of Park/Neutral swich 02 Caravan?
I was looking at the manual it tells you how to replace it but it does not show the location. I was getting nothing when I turned the key.
I trace the problem down to the Park/n switch as the relay is ok and when I jump the relay the starter kicks in. When I was checking the connectors unplugging and plugging back in on the Trans The car started, So I am trying to find the Park/Neutral switch and its connector. I understand the switch is in a part of the Tran, but I wan to check its connector and if there is any adjustment.
Thanks for any help or fixes!
Old 04-04-2008, 10:12 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Location of Park/Neutral swich 02 Caravan?
May or may not be the same but, this is for a 99: http://www.autozone.com/az/cds/en_us...rInfoPages.htm
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 04-04-2008, 10:34 PM
Its not the same, My 2002 has the 41TE transmission, but thanks for trying.
Old 04-05-2008, 12:48 AM
jpb53 jpb53 is offline
41TE has a Transmission range sensor (TRS) it is in the trans on the valve body. The valve body has to be removed toreplace it.
Old 04-05-2008, 02:27 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Scroll further down in the link. It's there.
Old 04-05-2008, 02:46 PM
RIP I did scroll down and found it, I like how they call it a Transmission range sensor??
I did find that the connector was not plugged in all the way and it has a clip that locks the connector on and it was not in all the way also. So far so good, Hope that takes care of it.
Thank you so much for all the help. I have gotten a lot tips from this site that has saved me time and $$.
PS. Can you help my Kansas Jayhawks beat North Carolina tonight in the Final Four.
Thanks again!!!
Old 04-05-2008, 04:43 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Sure hope it was as simple as that. Maybe that was the start of some good luck for you and your Jayhawks.
