Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 04-04-2008, 11:17 AM
ajsmith14 ajsmith14 is offline
Question 2000 Olds Silhouette Heated Seats
My seats in my 2000 silhouette stoped heating. Is this a fuse that can be replaced or is there more to it?
Old 04-05-2008, 10:08 PM
Will Help Will Help is offline
Re: 2000 Olds Silhouette Heated Seats
No such luck. If you haven't seen any bad fuses, the problem is with the heating units in the seats. The heating wires in the seats become brittle and will break in the areas of the thigh pads. They will also break when a knee or childrens feet apply too much pressure in one spot. GM redesigned these and
they are fairly easy to replace. But a little pricey!!!
Old 04-07-2008, 11:53 AM
83cutlass 83cutlass is offline
95% of the time the seat bottom element is open as mentioned above. Occasionally its the seat back element. Rarely its both but I have seen that also.
Old 07-09-2009, 02:56 AM
madmax99 madmax99 is offline
Hi there
My dirvcer seat does not heat, neither bottom or back , where should I start my diagnosis ?
Thank you
