2002 Monte Carlo Black gunk in coolant resevoir.
Like i said i have an 02 monte and i have a check engine light that just came on so i looked at the engine and noticed the coolant resevoir has a sort of thick black fluid in there and it kind of looks like oil im not too sure.. I havent delt with cars too much but i know thats not right at all and had some other people check it out too. If anyone has any clue of what it could be it would be very much appreciated. Im in the marine corps and need to get to work everyday so i cant afford to have a problem like this one.
Re: 2002 Monte Carlo Black gunk in coolant resevoir.
Welcome to AF!
Sounds like you have a sludge problem. I'd get the cooling system flushed out very well, ( which will be hard to do if the gunk is severe.) I'd also check to see if your lower intake manifold gaskets are leaking. Air can infiltrate your cooling system and cause the coolant to sludge up.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
Alright thanks a lot, i will do just that.
Semper Fi |
I had this problem on another car and if the “gunk” is oil you may have a blown head gasket.
Is it using oil/coolant? Does it smoke or blow steam out the exhaust? If yes that could be your problem. Thank you for serving our country. Hope this works out.
If you can't get there in a Thunderbird, the trip ain't worth taking! |
