Thinking about buying a '97 SC2
I'm going to go look at a '97 SC2, 5 speed with 198k on it.The person is only looking to get $600 for it. The front fender is cracked and the guys says it leaks a little oil. He says he has to put a quart in it about once a week.
Anyone think this is worth taking a look at or not. Also is there any know problems with these cars to look out for. Going to look at it on Saturday April 5. Any feed back would be greatly appreciated. Thanks, Dan Last edited by dbudworth; 04-03-2008 at 04:41 PM. |
Re: Thinking about buying a '97 SC2
![]() General: Year ____________ Model ____________ Mileage _______________ Auto or Manual ____________ Color ____________ Been in any accidents Yes No Receipts of repairs/maintenance Yes No Price ____________ Engine: Rough idle Yes No High idle Yes No Missing/pinging Yes No Oil color ____________ Coolant color ____________ Oil leaking around valve color Yes No Windshield washer fluid level Full Low Leaves near vents on back side of engine bay Yes No (Indicates car has been sitting for a while) Fan on/off with A/C Yes No Engine mount (visual inspection) Yes No Battery terminal corrosion Yes No Wheels: Tire tread Good Bad Tire pressure (visual inspection) Good Bad Steel wheels or Aluminum Steel Aluminum Brake rotors Clean Rust Alignment (visual inspection) Good Bad Interior: Seat condition Good Fair Bad Glove compartment Opens Doesn’t open Radio Operation Yes No A/C operation Yes No Heat operation Yes No Engine temperature High Normal Low SES Light Yes No Window operation (all 4 windows) Yes No Windshield wipers (including spray) Yes No Window wiper condition Good Fair Bad Exterior: Rust Tons Fair New! Windshield cracks Yes No Scratches Yes No Light Operation (hi/low/signals/hazards/brakes) Yes No Test drive: Time elapsed to engine operating temperature from cold start High Normal Smooth shifts Yes No Drives in straight line Yes No ABS functionality Yes No Rattles High Medium New Power (doesn’t feel lacking or suffocated) Yes No Automatics: Reverse slam Yes No Idle in gear High Normal Low Smooth shifts through all gears Yes No Transmission fluid color _________ Transmission fluid level Normal Low Manuals: Clutch feel Normal High No movement with clutch pedal pressed Yes No Easy shift into each gear (car on) Yes No Easy shift into each gear (car off) Yes No I may have missed some things as I did this off the top of my head but it should give you a good place to start NOTE : The " yes/ no " were originally all the way to the right of the page. The forum would not allow this space. |
