Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-02-2008, 10:48 PM
rod2004 rod2004 is offline
growling noise when applied brakes rodeo2004
When I apply the brakes at a stop sign at very low speed, there is growling noise coming from the brakes.
It has been going on for months. I looked at the calipers and everything. Pads are still thick. Nothing is out of the ordinary.
what could it be?
2004 rodeo 3.2L 2WD
AISIN AT
http://www.isuzufaq.com/
http://forum.planetisuzoo.com/
http://isuzuforums.com/
Old 04-03-2008, 10:15 AM
Cat Fuzz Cat Fuzz is offline
Re: growling noise when applied brakes rodeo2004
Did you check both inside and outside pads and the inside of the rotor on all four wheels? Chances are, the inside pad on one or more wheels is down to the metal.
Old 04-03-2008, 11:56 PM
yeah, I looked at both pads on both sides. They are still way thick before that "tab" can scratch the rotors.
no bolts are loose. nothing that I can see wrong at all.
It's not that kind of "worn to metal" kind of noise. It's more like rumbling and shaking at the same time and then it went away for couple days.
Then suddely it just happenned again.
2004 rodeo 3.2L 2WD
AISIN AT
Old 04-04-2008, 12:58 AM
The only other thing I can think of is a warped rotor.
Old 04-04-2008, 01:30 AM
I only have 40k on it. Plus, if the rotors are warped then my steering wheel and the brake pedal should be vibrating at the same time but they're not.
That's why I don't think it's a warped rotor either.
I feel nothing at all except the rumbling and a small amount of shaking.
2004 rodeo 3.2L 2WD
AISIN AT
