Old 04-02-2008, 10:04 PM
BikerPaintballdude BikerPaintballdude is offline
1 RE SX 15", or 2 RE SE 15"
What would be louder, more reliable, and sound the cleanest? And I will prob have a 1606D mono hiphonics brutus amp, (or mabe the 1006D amp im not sure)
I can hardly drive and I already have 3 different setups for each different car I MAY get. Planning ahead never hurt anyone, and some of yall should try it, it works.
Old 04-02-2008, 10:13 PM
dbfreak147.5 dbfreak147.5 is offline
Re: 1 RE SX 15", or 2 RE SE 15"
well 1 sub properly powered and in the correct enclosure will sound alot better than 2 underpowered
so i would say go with the sx in 4.5 cubes @ 32hz
2 Orion HCCA 10'S
2 AudioPipe 3k's
Adam Whitehead
Old 04-03-2008, 02:39 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
2 SE's off a 1606 would be loud, thats just about a perfect match for them..
I highly doubt you'd be able to hear the difference between 1 SE15 and 1 SX15, some people even say the SE can get louder, but still sounds a million times better.. the SE is a SQ/SQL woofer, the SX is more toward SPL.. If you wanna sound the best go with a SE.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 04-03-2008, 07:27 PM
Ok I think Im going to go with 2 SE's cuz I got 4 responces on another forum saying the same thing about them. So should i go sealed or ported with them.
Old 04-03-2008, 07:53 PM
And did you mean one 1606 to each or one for both?
Old 04-04-2008, 01:23 AM
pre98zetec's Avatar
1 1606D will be perfect for 2 SE's..
How much space do you have to work with (car? truck? van? SUV?) If your in a car i highly doubt you will fit 2 15's ported.. and if you do you will have 0 space in your trunk and have to build the box inside the car (not a fun thing to do... been there...)
-Josh-
Old 04-04-2008, 01:30 PM
Ok I think Im going to make it sealed. So do they sound beter in a sealed or ported box? And I have the whole back seat of a truck to put it on. And are these subs any better then the Diamond Audio CM3's cuz this is practically the first setup I had planned out?
