Old 04-02-2008, 08:06 PM
oldsguy2 oldsguy2 is offline
03 Taurus SEL water on passenger floor
We had a bad storm yesterday and I found alot of water on the floor of the passenger's side. Heater fan did not work either, for a while. Temperature was near freezing and after leaving the hood up for an hour the fans worked.
First major rain storm after a heavy Ontario winter.
Any thoughts as to the cause.
Old 04-02-2008, 10:20 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 03 Taurus SEL water on passenger floor
Does your Taurus have a sunroof?
Have you checked the forum for the common cowl leak to see if it possibly applies to your car? Try the "Search this forum" feature from the Taurus forum main page for the keyword "leak."
Also, are you sure it's water and not coolant from a leaking heater core? You'd certainly be able to tell the odor of coolant....
-Rod
Old 04-05-2008, 06:43 PM
Willyum Willyum is offline
You should pull the blower motor assembly out and clean/dry it. The motor will sit in the water for some time while still trying to work and eventually likely be ruined.
Old 04-07-2008, 08:31 PM
doowrencher doowrencher is offline
This problem is a known issue at the dealership. There is a bad seal in the vicinity of the cabin air filter and the blower motor. My blower eventually shorted out from the constant water infiltration.
The problem originated after I brought the car to a quick oil change place where they pryed the cabin air filter out to show me how dirty it was and how I should replace it. The leaking occurred shortly thereafter.
When I brought the car to Ford, they told be about the bad seal with that model.
Old 04-08-2008, 11:50 PM
tripletdaddy tripletdaddy is offline
Where exactly is the cabin air filter? I've heard of it but never seen one, found one for sale or even in references. Sounds mythical to me.
Old 04-09-2008, 06:29 AM
The cabin air filter is on the passenger side just below the grill at the windshield. It sits directly above the blower motor (makes sense). It's not easy to remove. Mine was full of the little seeds from the trees, but otherwise not dirty after 3 years.
http://www.wikihow.com/Change-the-Ca...03-Ford-Taurus
Old 04-09-2008, 01:35 PM
shorod's Avatar
SHO No Mo
There have been some pretty interesting posts on this forum related to the cabin air filter. It sounds like some Taurii came with the filter, some did not. No apparent rhyme or reason as to which ones came with it and which did not. You may want to search the forum for "cabin filter" for some interesting reading on the subject.
-Rod
Old 04-10-2008, 03:39 AM
Well, I've determined why I'm so not familiar and informed about these air cabin filters on my vehicles. None of them have it. Not my 94 and 95 taurii and 95 windstar. The rest of my stuff is too old for that kind of nonesense. From what I have found from suppliers, newer models do have the filters, but no particular year seems to be when Ford added them to their vehicles, no rhyme or reason. Sounds like a car manufacturer.
Old 04-10-2008, 06:33 AM
I change the cabin filter on my '02 every year. The old one comes out black and nearly plugged with debris.
Old 04-10-2008, 02:50 PM
runfromcheney runfromcheney is offline
My mom used to have a 03 Sable LS that once had the exact same problem that occored under the exact same circumstances. You have a bad seal on the climate control system, and you will probably need to have the blower motor replaced as well.
-Anthony: Ford and Chrysler guy, aspiring weekend mechanic, and future 1988 Mustang notchback driver
Old 04-13-2008, 01:31 PM
Is there an inspection or repair the DIY person can do to find the bad seal?
Old 04-14-2008, 08:45 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Simply look at the black wiper cowl on the passenger side of the car. Is it flush to the windshield with no gaps? I bet not!
Ford updated the cowl and it is easy to replace. I also suggest replacing the blower motor and resisitor since they already got wet and will fail soon.
Old 06-19-2008, 02:59 PM
We had another good rain and I found where the cowl was warped on the passenger side and have concluded that that must be the problem. Thanks for your responses.
