Old 03-01-2003, 09:43 PM
civicHatch civicHatch is offline
Send a message via AIM to civicHatch
check the scenerio
I have a 88 dx hatch and i have come across some parts so im thinkin about goin for it but i want some imput and to make sure it will work.
A 92-95 si head, intake manifold, fuel rail, injectors, throttle body will they all work with my d15 and what else do i need. Can i just not hook up the v-tec at first, untill i can get a v-tec solinoid and other stuff. My d15 has like 160,000 mi, do u think it can handle the add stress, although it has been maintained pretty well. Please help me out, im planning a b16a but need somethin in the meantime to cure the duel point syndrom. Thanks
AC
anybody want clusters?
90-91 canadian cluster with tach and KPH
90-91 crx si cluster
88-89 dx cluster
Old 03-02-2003, 09:32 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
...to get anything out of the swap, you[re gonna have to convert to MPFi..
SOLD!
Old 03-02-2003, 10:51 AM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Theres plenty of info on the mini me swap....but converting to mpfi is the first step...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 03-02-2003, 11:52 AM
91BLKsi 91BLKsi is offline
Send a message via AIM to 91BLKsi
whast a mpfi?
Old 03-02-2003, 11:58 AM
91civicDXdude's Avatar
well he did say that the head comes with the intake mani etc.
just a hint, if you're staying non-OBD and using an external source to activate VTEC and you're using the d16z6 intake manifold, you CANNOT use the injectors. they are saturated injectors as opposed to peak and hold which non-obd is. you'll need injectors & injector resister box out of a CRX/Civic Si, unless you plan to convert to OBD1, in which you can use the d16z6 injectors.
Actually, i would recommend that if you are planning to stay non-OBD, i'd get a crx/civic Si intake manifold because all the vacuum lines are right there and easy to run as opposed to the d16z6 intake manifold which you have to reroute some vacuum lines.
Old 03-02-2003, 11:59 AM
marked001's Avatar
Moderadur
multi point (mpfi) uses 4 injectors... si, ex, hf
dual point uses 2.... dx
SOLD!
Old 03-02-2003, 12:37 PM
Stali08's Avatar
Stali08 Stali08 is offline
Send a message via AIM to Stali08 Send a message via Yahoo to Stali08
what does a lx have? too lazy to go out and check for myself
Old 03-03-2003, 01:57 AM
nemo_wolf's Avatar
nemo_wolf nemo_wolf is offline
Send a message via AIM to nemo_wolf Send a message via MSN to nemo_wolf Send a message via Yahoo to nemo_wolf
DPFI
AF Bay Area Crew
91 civic LX sedan : Dec. 3rd 01 - Dec. 9th 02
88 civic DX hatch : Jan 14th 03 - Oct 05
96 Zamboni Model 552 : done working there
00 Civic EX coupe : Oct 05 - Sept 2010
11 Scion xB : Sept 2010 - Present
