99 4x4 switch
Should the indicator light in the switch be on all the time, if it's not, where should i start looking for a remedy?
Has anyone changed the front output shaft bearing on the T-Case before? When I grab the front driveshaft and wiggle it, the movement is at the case. It's little but still noticable. |
Re: 99 4x4 switch
the 4 wheel drive switch light should be on at all times........it will flash twice when changing to different modes.. if it flashes too many times its got problems... how long have you owned/noticed this problem ? does 4x4 work ? did you check fuses with meter ? do you have any 4x4 service warning lights ? if so get DTC so that we can get you some help..... |
Re: 99 4x4 switch
I have the same issue with my 99. The indicator light randomly goes on and off while I'm driving. Sometimes, it just goes dim. It doesn't feel like it's switching in the transfer case, just the lights. The switch still works, the problem seems to be with the lights on the switch.
Re: 99 4x4 switch
Re: 99 4x4 switch
the switch seems to be fine, if i push on the housing it stays on. must be a bad connection. thanks for the reply's
Re: 99 4x4 switch
the removal and inspection of 4x4 switch takes 10min. i removed soldered and reinstalled the switch in 45min.... |
