Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-02-2008, 02:41 PM
Aces0vr8s's Avatar
Aces0vr8s Aces0vr8s is offline
Send a message via AIM to Aces0vr8s Send a message via Yahoo to Aces0vr8s
Rear end off line with body
The rear end in my 86 iroc sits about 1/2 inch farther to the right (passanger side) then it should. I replaced the bottem bar that holds it. It had a severe bend and it fixed part of the problem. It was way off to the point that the driver tire was completly under the wheel well and the passenger tire had about 4 inches hanging out, Now theres about 2 inches on the driver side hanging out and about 2.5-2.75 haning out the passenger side. Was wondering what else could possibly be bent that would do this. Im looking and I cant figure it out, But then itd only have to be bent 1/4 of an inch to off set it by 1/2, Any suggestions as to what should be replace? My dad and I have been looking for ages, It doenst seem to cause the car do pull or drive at an angle or anything along them lines, It just needs to be slid over, Any suggestions would be appritiated, Thanks, Brian
Old 04-02-2008, 07:11 PM
poormillionaire2 poormillionaire2 is offline
Re: Rear end off line with body
Sounds like you need a double adjustable panhard bar to center that rear.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 04-03-2008, 09:43 AM
Aces0vr8s's Avatar
Its amazing what a log chain, a 10,000 lb winch and a jeep can fix.
Old 04-05-2008, 09:42 PM
GreyGoose006 GreyGoose006 is offline
you did WHAT???
please tell me you didnt "pull" the rear end into alignment by yanking on it with a winch...
Old 04-07-2008, 09:48 AM
Aces0vr8s's Avatar
We loosened the bolts on that bottem stabalizer bar or whatever its called, Then we chained the actual subframe onto a poll so the car wouldnt slide and hooked the winch onto the axle and winched it over, then put the bolts back in on that bottem bar, then where oblonged shaped, Was the only way we could move it over with all the other crap thats hooked onto it.
Old 04-07-2008, 10:07 AM
goldz28's Avatar
goldz28 goldz28 is offline
wow
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering
Old 04-07-2008, 11:14 AM
Aces0vr8s's Avatar
Well we had replaced everything that appeared damaged. So we didnt have much other choice, no one we talked to had any other ideas. Id still like to replace whatever was originally damaged so if you have any idea of what it might be, do tell.
Old 04-08-2008, 01:50 PM
I'd start checking the subframe for trueness to the body
was the car previously wrecked badly?
Old 04-09-2008, 02:51 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
probably bent the control arms.
Old 04-10-2008, 12:50 AM
z28 boy's Avatar
z28 boy z28 boy is offline
Send a message via AIM to z28 boy
This kinda stuff cracks me up....lol
R.I.P. Andy, A great guy and an even better friend.
2000 Z28 A4:
Patriot 226 cam, Comp 918's, Comp Ti retainers, HSW 100 shot, Vig 3600 stall, Richmond 3.73's, 2.5in TD's w/ H-pipe & 1-chamber flowmasters, 160* stat, TSP Lid, K&N filter, MSD wires.
Buried Needle Racing!!!
Old 04-12-2008, 11:01 AM
Aces0vr8s's Avatar
Thanks to the people that helped, Were still trying to find the problem though. But in the meantime it had to be drove so it had to be fixed the best it could untill we can find whats wrong, Thanks again.
Old 04-19-2008, 05:33 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
very ghetto.
didn't start out working in a tyre shop, did you?
Seatbelts Saved My Life
