Old 02-28-2003, 05:34 PM
daggerlee's Avatar
Castrol Mugen NSX Progress Thread
Not much to show right now. I've snipped off all the parts that required to be painted in the body colors. These have been tidied up and will look good on the model (no visible ejector pin holes). They are attached either by mini alligator clips attached to Q-tip sticks, or toothpicks with Blue-tak.
Minor note: The side mirrors have a mold line on them on the inner part, which I sanded off.
Here's the body. Mold lines have been removed, and the roof was sanded to remove a little circular projection as according to the instructions. The mold lines run up the left and right front fenders and right/left rear fenders. The wheels in the background have been dechromed and will be painted in X-28 Park Green, then clearcoated.
Here are the parts that have ejection pin holes that will be visible after assembly, so I'm filling them right now with Mr. Surfacer 500, then sand until dry. Mainly the parts of the wing, the fuel intake, and some fins on the front bumper.
The parts are waiting for priming, I will be priming them with Gunze Sangyo Base White from an airbrush. I want to do them all at once, so while I fill the ejecter holes on the above parts, I cover the rest in plastic wrap to keep dust off.
After priming, I will paint the front bumper first, as it will be the most time consuming one to paint. I'd rather get it out of the way first, since it's so complicated and there's much room for error. You can see here
Next update will come after everything's been primed, and hopefully I'll be able to take you through the painting of the front bumper. I'm not in too big of a hurry to finish this, I'd rather get it right and proper.
Dan
Old 02-28-2003, 05:37 PM
supratuner's Avatar
its looking good! cant wait to see it finished
Old 02-28-2003, 05:39 PM
JDM Evo7 JDM Evo7 is offline
That's one of the most detailed write ups I have seen. Good job!! I don't envy you at all on the front bumper.
Old 02-28-2003, 05:40 PM
Veyron's Avatar
Veyron Veyron is offline
Thumbs up
You've got a good start, it's going to be careful work to get right but will be a stunning piece.
Old 02-28-2003, 05:54 PM
flyonthewall's Avatar
Car Mod guy
Looking forward to this one Dan!
I have a Raybrig version on its way with a view to creating more transkits. I'm glad u posted a pic of the instructions showing the body construction coz i was hoping the front was a seperate piece for my planned conversion!
Old 03-01-2003, 09:24 PM
k_dog's Avatar
k_dog k_dog is offline
Send a message via ICQ to k_dog Send a message via AIM to k_dog Send a message via MSN to k_dog Send a message via Yahoo to k_dog
question.....i jst got this car....how would i go about doing the front air dams' paint job..its 3 freakin colors
Brian
Old 03-02-2003, 01:53 AM
Asmenoth's Avatar
Asmenoth Asmenoth is offline
AF Premium User
I just finished mine, except the rear wing (might have to repaint, didn't come out glossy...I suspect the high humidity the night I sprayed it)....they finally showed up and the seat belts for the Corolla were driving me nuts so I set 'em asside for a day or so. I just used strips of masking tape, cut 'em into peices and masked off the front bumper. A hell of a masking job, though it came out better than I thought it would (minimal touching up with a brush). The decals on this kit are interesting though, they seem a bit thick...but go easy on the micro-sol.
Do you know how fast you were going son?
No Officer, the speedometer only goes up to 85.
Old 03-02-2003, 02:22 AM
RallyRaider's Avatar
Zomby Woof
That NSX looks like a stunning kit. Please keep us posted on progress Dan, definitely take your time and get it right and proper.
Old 03-02-2003, 03:16 AM
Guido Guido is offline
Hi Dan,
Looks like a thourough plan you had before starting. Good thinking and a good start to another nice build-up!
Keep 'em coming
Old 03-02-2003, 05:47 AM
daggerlee's Avatar
Brian
It's actually 4 I'll see what I can show as I paint mine
Dan
Old 03-02-2003, 07:06 AM
bigfrit's Avatar
bigfrit bigfrit is offline
Good luck!
you seem to be heading nicely with your NSX!
Bo, am I happy I chose to buy the Mobil 1 NSX, instead of your paint-monster!
Ciao and good luck!
Olivier
Old 03-02-2003, 07:56 AM
Looks great so far. Keep us updated!
Old 03-11-2003, 06:42 PM
daggerlee's Avatar
After the wing and front bumper parts were sanded, everything was primed with Gunze Sangyo Mr. Base White primer. The stuff is pretty good, a flat white that covered the black pretty well. While no cheap sprayable quality white primer exists, I will continue to use Gunze.
After the first priming, dust that made its way into the paint job and imperfections in the sanding were sanded out with 3M 1500 grit sandpaper, then all the touched up parts were primed again.
Now, the process of painting the body begins. The front bumper and front two fins of the body were sprayed TS-26 Pure White that had been decanted into a bottle and sprayed through my airbrush. This was somewhat of a bother, I had to sand out some dust and such that made its way in (white is the most unforgiving color) but after everything was proper, I gave it a 'dirty' clearcoat with TS-13.
You can't really distinguish between the primer and paint in the pics. If you look at the bottom of the front bumper, you can see air bubbles from the clear being sprayed too thick Luckily, they're on the part that will be painted Park Green, so they will be sanded out tomorrow. I'll be back with the masking process and tricks as I get ready to spray Park Green onto the bumper, various parts, and the hood of the body.
Dan
Old 03-11-2003, 06:48 PM
k_dog's Avatar
Dan, very nice indeed.
Curious to see the paint job progress....
Keep us updated!
Brian
Old 03-11-2003, 07:14 PM
kunta's Avatar
kunta kunta is offline
good job! thanks for detail report.
I also use Mr. Base White primer and gray primer by airbrush.
when base plastic color is black, I always apply gray primer first.
did you apply white primer just twice? it looks so white...
