Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 04-01-2008, 08:26 PM   #1
iron141
lube question
I have a 2003 xterra 4x4 it is hitting 90000 miles. I changed the plugs and the coolant. Just wondering if any parts need to be lubed? any greese fittings? if so any how to areas on how to keep it running well. I also already changed the brake pads. but nothing else done. to vehicle. thanks
iron141 is offline   Reply With Quote
Old 04-01-2008, 09:36 PM   #2
OffroadX
Send a message via AIM to OffroadX
Re: lube question
Only lube item is the front driveshaft. Takes a special needle, or swap the fitting for a conventional grease fitting. Search here for more info and pictures.
When did you last check your spare tire's pressure?
OffroadX is offline   Reply With Quote
Old 04-03-2008, 09:10 PM   #3
iron141
Re: lube question
I can't find any pictures or information any links?
Old 04-03-2008, 09:10 PM   #4
iron141
Re: lube question
Old 04-07-2008, 07:46 PM   #5
OffroadX
Re: lube question
