Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 04-01-2008, 10:48 AM
Nivek1 Nivek1 is offline
p1404 egr
I have this code in my 2000 Montana....looking in forums seems common my question is seeing that it is a pita to get too...do you replace egr or cleaning will fix problem...
Of all the things I lost ....I miss my mind the most.
Old 04-04-2008, 11:34 AM
rockwood84 rockwood84 is offline
Re: p1404 egr
most of the time you can clean them with carb cleaner.make sure the piston and the seat where the piston seats are clean.
Old 04-04-2008, 12:49 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: p1404 egr
I tried cleaning mine. Didn't last too long before having to replace it.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 04-05-2008, 08:50 AM
hufhouse's Avatar
hufhouse hufhouse is offline
Re: p1404 egr
Just a "heads up." I got that code (and replaced both the EGR valve and the MAP sensor) on my '02 Saturn and it didn't go away. Within a few days, it became apparent that the catalytic converter was clogged, causing back pressure into the manifold.
Different car, but the same code. Thought I would throw it out there.
