it ran fine this morning went out after work to go home and it started then died, have lights, radio buzzer but wont turn over and no clicking when turning the key very
please help this is my second car and know its down both out....
Re: 1995 dodge grand caravan wont start
How old is battery? Have you checked battery terminals and cables? Check for voltage at starter, check all grounds. |
http://www.autozone.com/az/cds/en_us...rInfoPages.htm I do not see a 40 amp fuse in the diagram for the Power Distribution Center. If I get a chance I will look at a friends Voyager. Check the starter relay. I would double check the cable going to the starter and also the small wire to the starter solenoid. Also the ground cable to engine. There is a short someplace to keep blowing fuses. You could also remove the cable at the starter and see if it still blows fuses if not then the starter has a short. Take loose the Power Distribution Center and look at the underside for corrossion? I realize you want to get it home as cheaply as possible but I would consider renting a car dolly from U_HAUL or someone and tow it home so you have easy access to working on it. Did it backfire or anything out of the ordinary when it died?? Hopefully someone will chime in with other possiblity's. Keep us posted and we'll get you thru this. |
hey the hubby just informed me that its not a starter fuse but a ignation ( mispelled sorry about that) fuse under the hood by the battery so i think he is going to look at steering colom and see if he see anything. what do you think? can always use ideas
Disconnect the steering collom wiring at the base of collom and see if fuse blows. |
