Go Back   Automotive Forums Car Chat > Honda > Exterior | bodykits | Lighting
Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 02-28-2003, 03:59 PM
drkaos drkaos is offline
Question 2001 Civic Si bumper cover removal
Any one know how to remove the rear bumper cover? I'm not sure how it's attached....ie where all screws are , if attached to rebar etc..
ANY help would be appreciated.
Thanks for the space....
Old 02-28-2003, 04:19 PM
CivicLx CivicLx is offline
I've got a 98 civic with a Black Widow back on, but it's probably not too different removing your bumper. Look for a screw at each side near the wheel well and then there's some clip thingies in the trunk area that pop out with a flathead screw driver. That's all there is to secure my back bumper. Hope this helps.
Old 03-03-2003, 11:54 AM
BrokenLimits BrokenLimits is offline
Send a message via AIM to BrokenLimits
Do you live in Canada? They didnt make a 2001 Civic Si....
Brandon
Columbus, OH and Orlando, FL
2000 Civic Si with fully built LS VTEC
Old 03-03-2003, 12:27 PM
Ok....Brandon then it is a 2002..its not my car.
Anyways....Thanks for everyones help.
To remove the bumper:
- Remove screws from under the wheel well ...on each side.
- Open trunk and you should see two black plastic plugs on the bumper cover (remove with flat screw driver)
- Remove the two 10mm screws
- Look underneath the bumper there will be two more black plugs (remove them)
- Now gently pull the bumper off...it should snap off...its only holding on by clips.
Whole thing shouldn't take you more than 10 min.
Old 03-05-2003, 05:45 PM
I was just asking because if it was a 2000 I could tell you how...
Brandon
