Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 03-30-2008, 06:06 PM
99MBSport's Avatar
99MBSport 99MBSport is offline
Wiper arm removal??
I am trying to remove the front wiper arms. I have removed the caps and nuts but the arms do not pull up. I did tap the threaded wiper arm stud but it appears that it is not letting the arm go but rather driving the shaft out of the pivot. Now the pivot is loose. Can this be fixed or do I need to replace the assy. It appears that I am going to need a puller to get the arm off the shaft, but now the shaft has a upward and downward motion. Thanks for any advise on what to do.
Old 03-31-2008, 05:29 AM
Headnsouth's Avatar
Headnsouth Headnsouth is offline
Re: Wiper arm removal??
Its a splined shaft that should pull straight off. Spray a bit of WD40 or the like and tap the shaft gently with a small hammer.
03 GMC Sierra 100k
05 Infiniti G35 150K
10 Mazda 3 Hatchback 110K
16 Infiniti Q50 Red Sport 34K
Old 04-05-2008, 10:32 PM
wafrederick wafrederick is offline
Banned
Get your self a battery post puller,it is also the puller for the wiper arms.You can get it at any parts store.WD40 is worthless as a penetratating oil.
Old 04-09-2008, 08:31 PM
99MBSport's Avatar
Ya I usually use PB Blaster, I found this way better when I was redoing my 85FieroSE 2M6
