Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 03-30-2008, 02:11 PM
danielsatur danielsatur is offline
Driver Door Electric Window Pbl
There's alot of wear & tear on this window switch!
The drive-up ATM's & MC'Ds,will cause this problem.
1) Don't buy the whole drivers door control switch,because it's too costly.
2) Go to the junk yard and buy the rear window control switch,this one
isn't used as much.
3) You can take these switches apart for repair.
Note: Works with 1995-1997,I'am not sure about other models.
Good Luck!
MCGIVER
Old 03-30-2008, 02:53 PM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
Re: Driver Door Electric Window Pbl
On the 91 to 95 model TC the master window switch dosent come apart, and can't be interchanged with the single ones. The master window switch is all one unit as well as the single switches. The rear window single switches and power lock switches are the same and can be interchanged. The seat switches do come apart and can be cleaned. I don't charge an arm and a leg for these switches, like some people. The master switch is the most expencive, since it is the one that everyone wants. I ask 25.00 for the master switch. 19.99 for the seat switch and 9.99 for the single window/ lock switch.
See link below for a picture of the master control switch for 91 to 95 it may fit the 90 But I haven't confirmed that. It does look like it is made up of the smaller switches but it isn't.
http://cmasalvage.com/90stc_mw_switch.jpg
Mike aka JYD
