Old 03-30-2008, 12:11 PM
03impala9c1 03impala9c1 is offline
cruise problem
so the cruise light will randomly blink on and shut off usually right away... it mostly happens when the car is not moving and the cruise does not work... the buttons seem in great shape and i dont even have to touch the buttons for the cruise light to work. any idea of whats wrong here?
***5 WAYS TO KNOW YOUR A REAL MECHANIC***
1. YOU HAVE NO IDEA WHAT THE TERM "ANTI-SIEZE" IS.
2. ADD-A-WRENCH (EXTEND-A-WRENCH) IS YOUR BEST FRIEND
3. YOU KEEP A 3 FOOT PIPE IN YOUR TOOLBOX TO PUT ON THE END OF YOUR BREAKER BAR AT ALL TIMES
4. YOU HATE MECHANIX GLOVES AND USE THEM AS RAGS
5. EACH TIME YOU TAKE A SHOWER YOU SPEND MORE TIME CLEANING GREASE FROM THE SHOWER ITSELF THAN YOU SPENT CLEANING YOURSELF!!
Old 03-31-2008, 05:07 AM
tripletdaddy tripletdaddy is offline
Re: cruise problem
I think this one is for you Rod.
I'll just get in the way.
Sorry 03impala9c1
That's quite the project car.
Old 03-31-2008, 12:48 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: cruise problem
Okay. I'll have to get out the service manual and wiring diagrams.
03impala9c1, would you believe me if I said my 1998 SHO was one of the most reliable cars I have had? [It's too early for me to say if my 2007 Infiniti G35 will take that honor, but it's off to a good start.] The only problem I really had with my '98 SHO was coil packs. The radio illumination also quite working early on, but that wasn't a "problem," just an annoyance and was easily fixed in an afternoon with a soldering iron.
-Rod
Old 03-31-2008, 09:21 PM
shorod's Avatar
SHO No Mo
Re: cruise problem
There's just nothing jumping out from the wiring diagram. If I remember correctly, the indicator is only supposed to come on when the cruise is on and set. If that's the case, it would seem like the problem must be with the instrument cluster. Otherwise, there's a problem in the cruise servo or two buttons in the steering wheel assembly through the clocksprings would have to be shorting out in the correct sequence (on followed by set/accel). It would only take one short to ground in the instrument cluster to cause the indicator to light, and that would set the indicator without actually causing the cruise to come on and function.
If you get the indicator to come on reliable in error, check the orange/light blue wire from the cruise servo for a hard ground, rather than just floating.
-Rod
Old 04-01-2008, 12:32 AM
Re: cruise problem
thas the thing though also, my cruise doesnt even work!
