Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 03-29-2008, 10:37 PM
ittybittytrucker ittybittytrucker is offline
Chev. pickup
Hi there,
I have a 1998 chev pickup-5.7 v-8 engine 350.The engine will not start,I have replaced the dist.,rotor,dist.cap,plug wires,coil,pickup coil,modual and plugs.it has good compression,has fire,getting fuel and set timing on tdc.--someone please tell me why this truck won!t run.
Thank you
Larry
e-mail is [email protected]
Old 03-30-2008, 01:20 PM
72chevelleOhio 72chevelleOhio is offline
Re: Chev. pickup
Not Champion spark plugs I hope....
I had an ignition module bad that would only hit on every other cylinder. or every 3rd cylinder anyway...
Old 03-30-2008, 05:42 PM
rhandwor rhandwor is offline
Re: Chev. pickup
I think you might have set the timing 180 degrees off. This is a common mistake when rebuilding an engine and have done it myself. Usually you will get a slight backfire. Try turning the distributor slightly if it don't start try moving it 180 degrees.
If you have compression spark and fuel + air it should run.
Old 03-31-2008, 01:20 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
Re: Chev. pickup
was any work done on it before this happened ?
any symptoms lately ?
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
