Old 03-29-2008, 08:38 PM
ibewhand's Avatar
ibewhand ibewhand is offline
lumina "bucks" above 50mph then dies when brakes applied
1993 3.1 lumina euro
138k miles
this car cranks and idles fine, has to be driven for 20 to thirty minutes before troubles start. replaced fuel filter, plugs and wires, on thursday. on friday the wife drove car until it died and wouldnt crank, had to leave it in a parking lot overnight. went back this afternoon and the car still wouldnt crank so we pulled it home. once at home i removed the ECM fuse for about 20mins. replaced fuse and the car fired right up! drove it around for about half and hour before it started "bucking" again.
replaced :
ignition module -- last summer
spark plugs--
plug wires--
fuel filter--
ive been searching through this forum for an answer but have not found anything that really describes the trouble .
Old 03-30-2008, 09:13 AM
maxwedge maxwedge is offline
A990 racer
Re: lumina "bucks" above 50mph then dies when brakes applied
Welcome to AF.Won't crank means what? Won't turn over or turns but will not start. If it turns but will not fire do you have spark when this occurs?,wll it fire if you spray carb cleaner into the intake, all basic diagnostics.
Old 03-30-2008, 10:34 AM
ibewhand's Avatar
sorry wedge, the car would turnover, but wouldnt start. the car will start and run fine now, but after driving around for a half hour it starts to "buck". sometimes when you stop it will die.
the check engine light is not on .
could these be symptoms of a bad crank positioning sensor? or clogged egr?
or could the ecm be going out?
Old 03-30-2008, 01:52 PM
A990 racer
Start with checking fuel pressure and spark as I said. 35 psi at the rail.
Old 04-01-2008, 03:11 AM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
Minimum 40.5, max 47psi @ the schrader valve, key on engine off, GM specs. When was the last time that the trans was serviced?.
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Old 04-01-2008, 02:57 PM
A990 racer
Not to be argumentative, but mys specs show 24-40 psi depending on engine load.
Old 04-06-2008, 04:56 PM
ibewhand's Avatar
i have been working out of town and have not had a chance to check the fuel pressure yet. hopefully i can do it this week.
i am the third owner of this car, and i have never had the trans. serviced.
Old 04-06-2008, 06:30 PM
cadgear's Avatar
cadgear cadgear is offline
It actually sounds like the transaxle is locking to the crankshaft, and when he applies brakes it does not release. The bucking, depending on how severe, could simply be the solenoid sticking in a apply-release cycle.
Just a thought.
Old 04-06-2008, 07:04 PM
ibewhand's Avatar
how hard is it to locate and disconnect the TCC?
Old 04-07-2008, 12:21 AM
Bearwulf's Avatar
Just a thought.
And not disengaging when brake applied and vehicle slows down, therefore killing engine when car stops. Try shifting into neutral when stopping.
My fuel press. specs came from the GM Chevrolet Service Manual, 1993 Lumina.
97-Lumina LS
Old 04-07-2008, 03:31 AM
cadgear's Avatar
"has to be driven for 20 to thirty minutes before troubles start." sounds like the time for the transaxle to reach normal operating temp, give or take. I'm willing to lean towards the transaxle being an issue, given that fuel is eliminated.
Old 04-12-2008, 12:02 PM
ibewhand's Avatar
i disconnected what i assume is the tcc connector. i drove the car for a few miles and noticed that there was no overdrive. did i disconnect the right one?
the car still bucks, however not the same.
Old 04-12-2008, 01:22 PM
A990 racer
All one connector on the 4sp trans, you can only disconnect this for test purposes do not leave it off, bucking is not the same because there is less load on the engine with o/d and tcc disabled. Based on you statement in the original post this is not a trans related issue. Your getting off trac here, a no start or difficult restart is always engine related.
Old 04-12-2008, 03:25 PM
ibewhand's Avatar
ok so lets get back to the basics. I bought a fuel pressure guage.
key on engine off: 40-42psi
key on engine idle: 38 psi
what's next?
"the light that burns twice as bright, burns half as long."
Old 04-12-2008, 03:29 PM
A990 racer
Possible misfire under load, bad plug, wire, coil are some, dirty injectors, a full scan while the condition occurs then a freeze frame to look at possible misfire counts, also look at tps reading being erratic, no quick answer here.
