Old 03-29-2008, 07:40 PM
jefro2729 jefro2729 is offline
tranny swap help asap
i just put a 88 si tranny onto a 91 hf engine.everything seems to be working ok but the rpms are running a good bit higher,is this ok or do i have a problem?please help leaving the state tomorrow and if i need to swap it back i will.thanks guys
Old 03-29-2008, 09:55 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: tranny swap help asap
The Si trannies have a shorter gear than the HF and the lower other lower models. This results in a little higher RPM, nothing to worry about.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 03-29-2008, 10:58 PM
will it cause to much stress on the weaker engine?
Old 03-29-2008, 11:20 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Engine isnt necessarily weaker (not in stock form anyway). But the way it was built and the cam it has in it wont let it make a whole lot of power up top anyway. It was made for high mpg cruising, but no it wont hurt it..unless its got like 250k mi on it lol.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 03-29-2008, 11:27 PM
its got 213k on it lol so what does that mean?
Old 03-29-2008, 11:55 PM
FrodoGT's Avatar
That if you push it real hard you will begin to burn oil.
Current project:
Rio Red 91 hatch.
Old 03-31-2008, 11:49 PM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
lol be easy on the old girl..
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 04-17-2008, 02:35 PM
monotech's Avatar
monotech monotech is offline
Not to worry thats a good upgrade from Dx to Si. Definitely shorter gears which gets you out of the hole faster and well worth it.
